Secondary Tachometer (RPM Gauge) best way to wire?
Old May 14, 2019 | 08:52 PM
Dlansdell97's Avatar
Dlansdell97
Default Secondary Tachometer (RPM Gauge) best way to wire?
I’m looking for the best most accurate RPM output for my new gauge. I need to splice my wire into the best possible wire that reeds all 6 cylinders. Please help!
Old May 14, 2019 | 09:27 PM
bealljk's Avatar
bealljk
reeds?
whats your need for a duplicate RPM read?
Old May 15, 2019 | 02:49 AM
karlt's Avatar
karlt
Your will probably have to tap into one of the ignition coil wires. The tachometer signal you read on the instrument cluster is a digital data word sent from the ECM through the Unified Meter and A/C Amp to the gauges.
Old May 15, 2019 | 06:12 AM
g356sp's Avatar
g356sp
If you just want a digital readout you can get a obd scanner and display the output on your phone.
Old May 16, 2019 | 05:53 AM
Cracka350's Avatar
Cracka350
What I'm wondering is, did you get all new gauges or are you actually putting in a secondary tach? And if so, why?
Old May 16, 2019 | 08:28 AM
bealljk's Avatar
bealljk
My initial thought was nitrous
Old May 16, 2019 | 03:57 PM
coletrickle74's Avatar
coletrickle74
Nah that would be something worth talking about. He probably just wants a huge one to mount in a dumb spot to look cool.
Old May 16, 2019 | 06:46 PM
mr. sparco's Avatar
mr. sparco
I've seen a few members replace the stock tach with an aftermarket one. IIRC they also had swapped motors.
Dlansdell97
May 2, 2019 03:35 AM
sssmasss
Aug 23, 2011 10:51 AM
emir
Dec 29, 2005 04:46 PM
