HELP: The infamous Bose amp cutting out issue...What to do ?!?!
Old May 18, 2019 | 03:34 PM
3_dead_trolls's Avatar
3_dead_trolls
Exclamation HELP: The infamous Bose amp cutting out issue...What to do ?!?!
Soooo, Im sure quiet a few of you have dealt with this issue and read posts on the fixes (temp and permanent).
I myself have been dealing with the issue for a couple of years now. All of my setup is stock (Bose). I have tried the cardboard on relay fix a couple of years ago, which fixed the issue for a while but now its back... and ofcourse its super annoying.
I took it to a local shop who recommended me getting a new Bose amp. I found a used one on ebay and tried it out on my car...same issue Super frustrating.
They are now recommending that i buy a "new" Bose amp which will apparently fix the amp & the sub going in / out issue, but im not confident that it will be a permanent fix as its the the same part (bose amp) again and will fail eventually. The price i was quoted for the new bose amp is $300 bucks.
I also went to an aftermarket stereo shop. They pretty much told me to either replace the sub (but it will use the same bose amp) which probably wont fix the issue or replace the bose amp for an aftermarket one for which i will need to get a new head unit as well. (total cost including labor = $700).
The Z is my daily and i dont particularly want to drop this much money ($700) to change the whole setup to aftermarket (rather spend the $$ on my weekend car) I haven't yet gone to a dealership yet but was thinking about doing that next.
Do any of you have any other fixes they have tried for this particular issue? Thoughts? Am i missing something?
Thanks
Old May 19, 2019 | 11:41 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Thanks
Having a second amp exhibit the exact same problems should tell you something. Like maybe its not the amp. Probably something in the HU, maybe pre-amp circuitry, wiring, or somesuch.
If you don’t want to replace the Blose (sic) system entirely, yer stuck replacing it piece by piece due to its “proprietary” nature.
Frankly, I’d much prefer to drop 7 bills into a daily since I’d be in that car much more than a weekend car... which would have an exhaust based “sound system” for enjoyment. 😆
Old May 20, 2019 | 03:17 AM
onecoolee's Avatar
onecoolee
I thought the microphone under the steering wheel had something to do with the volume and bass levels in the Bose setup. I remember some threads a long time ago (late 00s) where people were replacing the microphone with a resistor to prevent the volume and bass fluctuations. You might want to look into that too. I have the 2 Bose amps sitting in a box in my basement, both have been used for maybe a couple months, before I remeoved them and replaced the entire system with aftermarket equipment. If you need them, they are yours for a fair price. I guarantee they work and have low hours.
Old May 21, 2019 | 10:29 PM
3_dead_trolls
Yeah.....having the same problem with another amp and reading countless posts on this issue DID tell me something ! these amps are S*it
For those of you who dont want to spend 7 bills on a new system and be the kook kids on the block, here is what fixed my issue:
This is a permanent fix btw and it worked . I got this done and haven't had a single issue
Cheers
Old May 22, 2019 | 02:50 AM
travlee's Avatar
travlee
Master
https://youtu.be/Pb-6utVaPPI
Cheers
this fix has been around for years.... a simple search in the beginning would have led you to one of the numerous threads covering this
Old May 22, 2019 | 05:37 AM
onecoolee's Avatar
onecoolee
Thx for this info, I didn't have my Bose system instaleld long enough for the amps to fail. If anyone needs help with this repair, I can do the work...I have a professional solder/re-work station.
If you are happy with the sound of th estock Bose, then this is the simple and cheap fix.
I have the under the seat amp and the sub amp, and Bose subwoofer, all like new w/ low usage, should anyone needs those parts for their 350Z. I have the stock speakers too (pillar tweeters, door mid, and rear mids), if anyone needs them. The rears require a close to complete gutting of your Z for installation.
Old May 22, 2019 | 05:49 AM
iideadeyeii's Avatar
iideadeyeii
*Checks price of my factory bose amp on ebay. Sees $30. Throws in trash*
Old May 23, 2019 | 05:13 AM
ajpasa's Avatar
ajpasa
I have done this fix on mine, paid 7 bucks for the relay on amazon. Works like a champ.
Br,
Al
Old May 23, 2019 | 09:34 AM
3_dead_trolls
Exclamation
Br,
Al
Would you mind sharing the link for the relay part you found on Amazon?
Want to have this handy for future reference...in case the OEM relay fails.
Thanks!
Old May 23, 2019 | 08:43 PM
ajpasa's Avatar
ajpasa
Sure, see if this works:
Amazon Amazon
br,
Al
Old May 23, 2019 | 09:09 PM
3_dead_trolls
Wink
Or a you could have made your post a bit more useful and shared the fix when i posted my question Even more simple and helpful
Old May 23, 2019 | 09:10 PM
3_dead_trolls
Thanks man! Much appreciated.
Old May 24, 2019 | 01:11 AM
travlee's Avatar
travlee
Master
I dont spoonfeed the lazy
Old May 24, 2019 | 10:33 AM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
This is the only correct way to fix the bose anything.
Old May 24, 2019 | 10:39 AM
ajpasa's Avatar
ajpasa
Well, different opinions are constructive of course. Mine works really well on a 2003 old car.
Issues are there if you want more base; and if you don't know what you are dealing with, in my opinion.
Does a 10" 250W RMS sub sounds louder and punchier? Sure.
Br,
Al
exZilaration
Feb 20, 2023 10:02 PM
white_sg
North West
17
May 16, 2018 07:27 PM
absurdparadox
Mar 21, 2011 06:28 PM
3hree5ive0ero
May 30, 2007 06:30 PM
Firemedic
Oct 25, 2005 01:35 PM
