Yet another Valve Cover Venting Question
Old Nov 16, 2019 | 04:31 PM
Kevin Skene's Avatar
Kevin Skene
Default Yet another Valve Cover Venting Question
Passenger side has a small filter on the PCV valve.
Does the driver side breather on back of the the valve cover have to pull vacuum or can i just put a filter on it and seal the hole on the intake tube?
Please excuse the clutter.
Old Nov 17, 2019 | 03:57 AM
Heel Til I Die's Avatar
Heel Til I Die
When I got my Admin intake, there was no port for the left side breather hose, so I have a filter on the valve cover towards the firewall. You can cap off the intake tube and use a filter to turn it into an open breathing setup. I doubt you'll pass inspection in CA since you're bypassing the PCV system.
Old Nov 18, 2019 | 03:51 AM
carder24's Avatar
carder24
If your referring to the hose that goes from the back of the drivers side valve cover, to the intake(I think you are , just making sure) I have forgot to attach it before and went like 200 miles before even noticing and i didnt notice any difference. So yes i think just filling the hole will be alright.
Old Nov 18, 2019 | 07:23 AM
karlt's Avatar
karlt
According to the Service Manual, the driver side valve cover pulls air from the intake tube under normal conditions and pushes vapors into the intake tube under high load conditiond.
Old Nov 18, 2019 | 08:10 AM
Kevin Skene
Cool thank you!
Kevin Skene
Filling the hole on the intake tube and venting the nip off the valve cover! Yessir, thank you.
Old Nov 18, 2019 | 08:11 AM
Kevin Skene
Thank you. It's a track only car so we're good
Old Nov 18, 2019 | 12:35 PM
260DET's Avatar
260DET
If it's a track only car why not vent both to the atmosphere via filters and one or two vent tanks. If venting is too restricted then crankcase pressure may cause seals to leak.
Old Nov 19, 2019 | 07:11 AM
Kevin Skene
Both are vented to the atmosphere now, a catch can/vent tank should probably be used for cleanliness
Heel Til I Die
Jul 19, 2018 06:56 AM
350Z400rwhp
Oct 23, 2011 08:53 AM
chodalak
May 12, 2011 08:06 AM
ReV2Red
Dec 9, 2008 05:51 PM
BriGuyMax
Jul 19, 2007 08:56 PM
