Oil leak
Old Dec 2, 2019 | 12:40 PM
SWOK561's Avatar
SWOK561
Default Oil leak
So I bought a 03 Z. Have been noticing little oil droplets on the garage floor after it’s driven. I have changed the oil filter O ring, oil pan gasket, and the valve cover gaskets and the covers themselves. Just been trying to replace parts that it could be. Only options I can think of now are the rear main seal, the crank seal, or maybe it’s the damn oil pan plug idk. Have noticed my oil pan has light oil on it. In the pic there is oil on that too. I’m lost lol
Old Dec 2, 2019 | 12:56 PM
260DET's Avatar
260DET
Clean first then identify where the oil is falling from by the location of the oil on the floor. Then look at where oil is dripping from the engine and then trace where it is running from the engine, that can be from two different places ie oil may be coming from higher up the engine and then running down to drip from a different part of the engine. Works for me.
Old Dec 2, 2019 | 01:27 PM
SWOK561's Avatar
SWOK561
I cleaned the area and am doing just that. Thinking about doing the UV test here soon
Old Dec 10, 2019 | 02:37 PM
icer5160's Avatar
icer5160
That's the A/C compressor right? So driver's side of the engine? Make sure your oil dipstick is fully inserted, it sits behind and above the compressor. Also make sure the dipstick rubber gasket/seal material is still intact. It's not uncommon for oil to spit out of there if the dipstick isn't properly seated.
-Icer
Old Dec 14, 2019 | 09:14 AM
g0lfball3R's Avatar
g0lfball3R
-Icer
I’ve seen it coming out of few areas of the timing chain case. Might wanna look at that? Lack of silicone? Bolts not tight?
davidmrqz3
Jan 6, 2017 08:05 PM
DOMO_03Z
Feb 5, 2014 03:10 AM
zinctokki2love
Aug 15, 2009 07:42 PM
Skrill
Aug 8, 2005 01:26 PM
jeffa55
May 5, 2003 08:32 AM
