too much oil? what happens?
Old Aug 13, 2009 | 09:31 PM
zinctokki2love's Avatar
zinctokki2love
Default too much oil? what happens?
i think my last oil change they put too much oil. I recently started smelling a burning smell, so i naturally checked the engine oil level thinking it was low.
to my surprise, there was oil all over the dipstick.
so is this bad for the engine? or does it just burn away?
thanks my350.com
Old Aug 13, 2009 | 11:14 PM
350Z400rwhp's Avatar
350Z400rwhp
If there is too much oil the crank will stir up the oil so much that it may foam and cause problems. So not good, sounds like you caught it in time though.
Old Aug 13, 2009 | 11:53 PM
*Boose*'s Avatar
*Boose*
Eventually it starts pouring out the drain plug. Found this out the hard way and most definitely not in the Z.
Old Aug 14, 2009 | 02:46 AM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
The oil tends to whip into a froth and will actually cause you to start burning oil, which sounds like that's what is happening in your case. Completely drain and refill. I'd take the time to do an long drain to get as much oil out as possible before refilling. And yes, it can cause damage.
Old Aug 14, 2009 | 04:53 AM
racerx300zx's Avatar
racerx300zx
How long after shutting the engine off did you check the level? While it's best to be safe, I'd check the level after the car had sat and see where it reads.
Old Aug 14, 2009 | 05:35 AM
zinctokki2love
oh man, i am the dipstick. haha, i read the oil stick the wrong side.
the other side its right at the H, so the oil level is ok.
so then, what is this burning smell?
I have an 05 with 60k. could it be I recently changed to synthetic?
Old Aug 14, 2009 | 05:55 AM
kham25's Avatar
kham25
Question i thought it was'nt a good idea to switch to synthetic with higher mileage cars?
Old Aug 14, 2009 | 06:18 AM
Parker01's Avatar
Parker01
How recently did you have your oil changed? It could be a number of simple things, they spilt some oil on your motor and the residue is still burning off, same thing with the underside, maybe there is some old oil around your filter/plug that is burning off... and finally old burnt oil may have dripped onto the top of you undertray and is sitting there.
Old Aug 14, 2009 | 06:44 AM
zinctokki2love
i had it changed two or three weeks ago.
Old Aug 14, 2009 | 08:37 AM
bryan@Z1's Avatar
bryan@Z1
Vendor - Former Vendor
Yeah, if the drain plug is loose.
Old Aug 14, 2009 | 03:03 PM
superchargedg's Avatar
superchargedg
Damn Noobs
WTF and how the *** is it gonna come out the drain plug.I need to know what you are smoking to come up with this answer...........you might just qualify as the new Lawchick.
Old Aug 14, 2009 | 03:16 PM
mclovin.too's Avatar
mclovin.too
Old Aug 14, 2009 | 03:59 PM
MDK's Avatar
MDK
Originally Posted by mclovin.too
You see... it pours out the drain plug after you realized you just f'ed up and consequently have to change the oil.
*Boose*'s Avatar
*Boose*
Uhh negative. So here's the story. About 4 years ago I had a neon. They were notoriously known for bad headgaskets. So of course you constantly burn and leak oil. So one day I decided to visit my gf so I checked the oil. The dipstick was bone dry so I added 5 or so quarts. Began driving and about 20 minutes into the drive there began to be a terrible smell of oil and a huge smoke cloud.
I continued to drive and a police officer pulls me over. Asks what the problem was and I told him I don't know. After a bit I open the hood and the smell of burnt oil covers the engine bay. Also all over the exhaust manifold was soaked with oil. So I climb back in and arrived at my girls house and checked under the car out of curiosity to see oil not rushing but leaking out the drain plug. The drain plug was tight.
Old Aug 14, 2009 | 04:12 PM
*Boose*'s Avatar
*Boose*
Sorry for the double my ps3 has a size limit.
Anyway at my gf's house I did a drain and flush. I then poured the oil that was in the container into older bottles to return to autozone filled 7 quarts with the remaining oil. So basically all in all I read dipstick incorrectly.
Also don't put me on lawchick's level. I do not lie or make posts about things I do not know or not have experience with.
Old Aug 14, 2009 | 04:13 PM
*Boose*'s Avatar
*Boose*
Yes in shorter terms.
Old Aug 15, 2009 | 12:42 PM
superchargedg
Damn Noobs
I was just kidding about the Lawchick comment as nobody is that bad.
Old Aug 15, 2009 | 07:42 PM
vthao's Avatar
vthao
When you pulled the dipstick, did you clean it, put it back in, and check the level again? Sounds like you just pulled the dipstick and oil was all over.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Stevo Z
Oct 3, 2015 09:14 PM
