Oil Leak.....not fun.
Old Apr 27, 2009 | 07:24 AM
DOMO_03Z's Avatar
DOMO_03Z
Unhappy Oil Leak.....not fun.
Well i just changed the oil on the car for a second time since i had it now when i bought the car (03 z touring) it had a small oil leak, now from the looks of it, it looked like it was the oil pan gasket so i said what the hell lets change it so i bought the new gasket put some silicon on the oil pan and put it back on now i still have the leak.... i don't know what it is so i cleaned all of the bottom the oil pan and around it....next day everything was filled with oil and left a good amount of oil on the floor not a lot just about 5 inch oil spot, what else could it be???
cliff notes:
changed oil pan gasket
still leaking
what else can it be??
Old Apr 27, 2009 | 08:13 AM
Zeebra's Avatar
Zeebra
Check around your oil filter.. I had an 03 with a very tiny leak on one of the oil lines near the oil filter location.
Old Apr 27, 2009 | 08:22 AM
Troubleshooting a oil leak is a headache. Oil on the ground may not be helpful. Oil may take all sorts of directions before dripping to the ground.
Begin with a clean motor so you can see or feel oil.
Put some newspaper on the ground. A spot will give you an idea which side has a leak. Good luck.
Old Apr 27, 2009 | 09:08 AM
DOMO_03Z's Avatar
DOMO_03Z
thanks guys i might clean the bottom of the engine and also check those lines
Old May 1, 2009 | 12:53 PM
mclovin.too's Avatar
mclovin.too
+1 for a oil line around the filter. Maybe if you post up some pics we could help.
Good luck.
Old May 1, 2009 | 01:22 PM
DOMO_03Z's Avatar
DOMO_03Z
Well i'm thinking its the bottom oil line thats attached to the base of the oil filter thing cause it has traces of oil and that's really the only place that has the traces of oil.
Old May 1, 2009 | 01:55 PM
SchismX's Avatar
SchismX
Could it be the rear main seal? For your sake I hope it's not, because it can be a big PITA to replace.
Old May 1, 2009 | 03:42 PM
Jay.Diem's Avatar
Jay.Diem
post up some pix ... sounds like it may be lines
Old May 2, 2009 | 01:23 PM
DOMO_03Z's Avatar
DOMO_03Z
no its not i got it checked and fixed.lol it was a rubber hose that was attached to the oil filter thing and i replaced it and it stopped leaking.
Old May 6, 2009 | 02:33 PM
icase81's Avatar
icase81
My 06 had a split o-ring on the bottom of the dipstick tube causing a leak and under driving conditions would spray onto the exhaust manifold. Dealer fixed it no charge (obviously)
Old Mar 16, 2010 | 10:23 AM
tiger62's Avatar
tiger62
Okay, I can trump most of you (not a good thing). I have a 2006 that the entire engine was replaced (free thank God) and now it is leaking again. A good local local found the leak - here is what he stated --Oil is leaking from the Oil Filter Cooler Housing--
The dealership is fixing the new engine for free. I love my roadster but she spends more time in the shop instead of the road...
Old Aug 26, 2011 | 07:44 AM
mnkyd21's Avatar
mnkyd21
any idea of the cost of checking the oil leak?
Old Mar 27, 2012 | 06:46 AM
Z33Garage's Avatar
Z33Garage
I think the leak that I have is in this hose ( 21308] HOSE-WATER) (IDK why they call it a water hose when its for oil, unless its a generic name)
I notice that I have steam coming out of my passanger side of the car( and when I was able to crawl under the car, the pass-side headers were lightly coated in oil from the underside. Indicating a leak from this hose. The car drips about 2 drops a day, and the drip streams to the pass-side of the car.
http://www.courtesyparts.com/21308-h...8-p-13522.html
Is this hose usually an issue with you guy's cars?
Uploaded with ImageShack.us
Old Jan 23, 2014 | 08:41 AM
marcster13's Avatar
marcster13
I know this is an old post but this pic helped a lot! Thanks.
Old Jan 23, 2014 | 09:40 AM
Syner's Avatar
Syner
The image looks like it's from Courtesy Parts. Helpful diagrams w/ part pricing - definitely worth checking out if you haven't already.
Old Feb 4, 2014 | 10:22 PM
marcster13's Avatar
marcster13
Being a noob to the forums and the Z I have been doing lots of trolling. LoL I'll be sure to check out Courtesy Parts. Thanks!
Old Feb 5, 2014 | 03:10 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
That is a coolant hose, not oil. If you have an oil leak in the upper region on the passenger side it could be power steering or valve cover/cam solenoid. If the smoke smells sweet then it is coolant.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Stevo Z
Oct 3, 2015 09:14 PM
