Oil leak question/help
Old Dec 28, 2019 | 07:23 AM
Dcrunning's Avatar
Dcrunning
Default Oil leak question/help
Happy holidays everyone. Just looking for some help. I completed fixing most of the oil leaks. Changed the upper and lower oil pan(pain in the....) but o got it done. But I see oil coming from the radiator channel and electric fNs even though everything else is nice and dry. I have checked everywhere for this leak. It doesn’t make sense to see oil coming from radiator bottom channel. I don’t see oil in radiator. It’s not smoking, I have cleaned it with brake cleaner several times only to find it like this. I thought maybe it’s pressure only when driving so I have it up and jack stands and had someone rev it while I looked around and can’t see oil anywhere. Any thoughts? The next step was to remove electric fans and see what else I can see behind. Thanks
Old Dec 28, 2019 | 10:12 AM
CFAUVEL's Avatar
CFAUVEL
Are you sure it is engine oil?
if so isn't there an oil cooler mounted near the radiator ?
Old Dec 28, 2019 | 10:24 AM
travlee's Avatar
travlee
Master
Power steering maybe. What color is it?
Old Dec 28, 2019 | 03:17 PM
Dcrunning's Avatar
Dcrunning
It’s not red like the power steering. Plus it’s still full. It’s brown. Are there any oil lines that run under the power steering reservoir? Really not sure where it’s coming.
user 68320
Jul 24, 2016 07:14 PM
SIR_pierre
Apr 15, 2013 04:58 AM
GC71
Aug 7, 2008 06:42 AM
itsjiggajames
Sep 14, 2007 01:55 AM
