Clutch Questions.
Old Mar 22, 2020 | 09:12 AM
Franknbeans's Avatar
Franknbeans
Default Clutch Questions.
2005 - 350 - UpRev - Anniversary Edition.
Hey all, I'm going to replace the clutch and maybe flywheel. I am all stock and don't want the chatter of a light weight clutch kit.
I bought a kit from NAPA and wondering if I should of got one from Z1.
Napa Clutch kit.
Napa Flywheel
Or send this back and get the Z1 kit found here. ??
Old Mar 22, 2020 | 09:23 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Since you've already got the NAPA parts, I'd just install the clutch kit. Do a thorough inspection of the flywheel surface on the car before you commit to replacing it.
Old Mar 22, 2020 | 09:26 AM
Franknbeans
Anything I should be looking for? Haven't replaces a flywheel yet.
Cracking / wearing like a rotor?
Old Mar 22, 2020 | 09:52 AM
dkmura's Avatar
dkmura
You'll need to check for grooving and surface wear on the flywheel engagement surface. If it's so worn that it's no longer smooth and level, check the FSM for wear limits.
Old Mar 22, 2020 | 12:48 PM
Zelduh's Avatar
Zelduh
IMHO, doing a clutch without replacing or at least resurfacing the flywheel is a waste of time. If nothing else, have you considered a non-dual mass replacement solid flywheel?
Old Mar 22, 2020 | 01:34 PM
dkmura's Avatar
dkmura
It's almost impossible to turn a dual mass flywheel. After experimenting with an ultra lightweight Titon clutch and flywheel package almost 13 years ago, I reinstalled my original OEM dual mass flywheel and replaced the clutch disc and pressure plate. It's been quite reliable since then with over 75K thus far.
Besides, the OP has a new flywheel to use if the original is damaged beyond further use.
Old Mar 24, 2020 | 06:42 PM
Zelduh's Avatar
Zelduh
Good point, years ago most machine shops wouldn't even try. I've heard some are doing it now, but previous experience would preclude me from the effort.
I wasn't clear on his post in that he said he had the clutch kit, but mentioned "maybe" the flywheel. If he has both, then by all means, please do install the flywheel while you're there.
natemichael
Feb 13, 2013 09:11 AM
priscilla ls1
Jun 8, 2012 08:17 AM
payam404
Mar 6, 2010 08:11 AM
solarnrg916
Nov 26, 2008 10:41 PM
