Engine Swap
Old Apr 28, 2020 | 03:36 PM
jlambert's Avatar
jlambert
Default Engine Swap
So, How do you get the Torque Converter Support Bearing out? I'm doing an automatic engine swap into my manual trans car and need to get this out to install the pilot bearing.
It appears to be pressed onto/into the back of the crankshaft, and there is a slight groove/lip on the inside of the bearing - can it be removed with a specialty puller? The service manual does not discuss how to remove this.
Old Apr 28, 2020 | 05:16 PM
bealljk's Avatar
bealljk
I welded a large nut on it and forced it out. You can also apply heat to the outer-ring to assist with it coming out.
ZPearlZ
Apr 28, 2020 03:23 PM
turbotommy350
Jul 12, 2017 10:12 AM
RKnight
Southern California
Jul 15, 2011 07:40 PM
WHORPS15
Oct 19, 2007 09:15 PM
f00man88
Apr 11, 2007 04:49 PM
