Fuel Pump Upgrade
Old Oct 2, 2005 | 09:57 PM
cquence 350 [Z]'s Avatar
cquence 350 [Z]
Default Fuel Pump Upgrade
I want to upgrade my fuel pump with the Walbro pump. Just wanted to know how hard is it to get to and replace the fuel pump? Is there any DIY for this?
Old Oct 2, 2005 | 10:26 PM
need Z's Avatar
need Z
Fuel pump is behind the passenger seat. I think I saw a how-to for it... but I can't remember for sure one way or the other.
Old Oct 3, 2005 | 03:50 AM
DavesZ#3's Avatar
DavesZ#3
Download a copy of the Service Manual from http://carfiche.com/manuals007/
It has complete instructions on removing the fuel pump assembly. BTW, it's located inside the gas tank.
Old Oct 3, 2005 | 06:35 AM
westpak's Avatar
westpak
SFZCC
It is behind the passenger seat, you have to remove the bottom cover inside the storage compartment.
First you have to relieve the pressure in the fuel system by pulling the pump fuse and starting the car a few times until it just dies out as soon as it starts or wont start, usually 3 times or so will do.
Then remove the screws holding the ring that holds the pump down, disconnect hose to pump, then remove the pump assembly being careful with the oring it deforms if it gets wet, you might want to have a new one just in case standing by.
Once you have the assembly out the pump is held in by a little basket, remove that and the pump will come out. Now you have to modify that little basket to enlarge the slots so it will re-engage once you have the new pump in place which is longer so the basket wont clip in place unless you modify it, once you modify it enough so the new pump will allow it to hook in place reinstall.
Try to do this with a low fuel level as it makes it a little less messy.
Old Oct 3, 2005 | 06:39 AM
JCat's Avatar
JCat
Apparently, not available from carfiche anymore.
Old Oct 3, 2005 | 01:11 PM
cquence 350 [Z]
Thanks Gus! I will have my mechanic friend do this for me. I am too scared to do it.
Old Oct 3, 2005 | 01:41 PM
Badmonkey's Avatar
Badmonkey
Buy a new rubber o-ring gasket. The one that goes around the top of the fuel pump assembly. If any gas gets on it it expands and should not be re-used. There is a DIY for the modification somewhere on the net, I will try to find it.
Old Oct 3, 2005 | 01:44 PM
Badmonkey's Avatar
Badmonkey
That took all of 2 mins of searching!
Here ya go.
http://liljerk.morpheus.net/350Z/fuel_pump_install/
Old Oct 3, 2005 | 01:56 PM
DavesZ#3's Avatar
DavesZ#3
Downloaded too many times....
try this one....
http://defianceindustries.net/files/...vicemanual.zip
Old Oct 3, 2005 | 02:08 PM
cquence 350 [Z]
Thanks for all the help guys! Very informative.
kyin
Oct 15, 2015 05:54 AM
