What the hell is going on with my Z?
Old Jul 3, 2020 | 02:32 PM
Nick Sion's Avatar
Nick Sion
Originally Posted by calvin.w
I think my soul just died a little reading that. The previous owner really f*cked that Z up bad. When you said diesel, I started thinking "why tf would that even be a thing????" I'm guessing they went to a BP for the first time ever and looked at the green handles and thought "gReEn mEaNs dIeSeL." Oh BP....
Anyways, this story gave me cancer. Hope all works out brother!
Well I wish I had good news for you guys. I spent all day up at the shop. After everything done mechanically to it we still had the EXACT same issues aas before. Obviously I plugged in my uprev and grabbed DTC but no codes showed up. I checked and realised that this car did not have a battery cover piece (not just the cover the whole trim that covers the IPDM and cabin air filter) and I could see straight down to the ECU. Fearing the worst I pulled the ECU and it was most certainly fried, most likely got water seeping inside of it. I got an ECU from an 04 g35 MT and had the BCM married to it. This is what I got from uprev BEFORE having the ECU married to the BCM.
DTC from first start with ECU **UNMARRIED**
After having the ECU married to the BCM I still had P1564 and P0506 showing up, even after clearing the codes multiple times. I honestly have no idea what to do at this point, as of now I have a $7k paperweight in the shop and the ONLY thing I can think of is the flywheel is somehow f***ed and preventing the new motor from idling. Please, anything that anyone could suggest would be GREATLY appreciated. Even my mechanic has no idea what could be wrong.
EDIT: I realised that this ECU had been pulled from a g35 which had cruise control, so having P1564 is to be expected.
Thanks in advance
~Nick
Old Jul 3, 2020 | 03:16 PM
calvin.w's Avatar
calvin.w
This is the biggest oof I've seen here but I'm with you on feeling the pain brother....
Hopefully you can get some guidance from @dkmura @MicVelo or @itsLeon
Old Jul 3, 2020 | 06:08 PM
Nick Sion's Avatar
Nick Sion
Here's a compilation of the issues I've had.
The clips are a touch out of order, the second clip should be the first.
Old Jul 6, 2020 | 06:44 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Not sure that I have any constructive advice after reviewing this thread and the video in the last post. I hope the OP picked up this much abused Z for a song, as there's a boatload of work to make it run properly again. It all comes down to gumption (which was a term used in Zen and the Art of Motorcycle Maintenance) and how much you have to continue to work on this project car. I think most of the DIY stuff has been covered already, and it's time to bring in a pro shop when you can afford it. This is not a project that will be solved via keyboard instructions. .
Old Jul 6, 2020 | 07:54 PM
calvin.w's Avatar
calvin.w
Put it in rice?
Old Jul 8, 2020 | 11:51 AM
icer5160's Avatar
icer5160
Man....I don't even know what to say. That poor Z, such a shame that someone would put it through so much abuse. You've already done all of the things I would've thought of and then some. A pro will be needed to get things sorted. I am curious about the new DE you put in it. Did you source a longblock? Did it include sensors and fuel injectors? Seeing as you had diesel in the tank, I can only guess that you still have fuel delivery issues. Perhaps the fuel lines or injector rails are clogged up if you're still using the originals.
-Icer
gabez33
Oct 15, 2014 11:29 AM
gossf
Sep 3, 2014 09:16 PM
TayEvt
Apr 4, 2014 02:04 AM
ickis
Aug 11, 2013 10:01 PM
ftball9656
Aug 31, 2008 07:08 PM
