fastener questions - trunk area
Old 11-21-2020, 12:24 PM
nickpapp
nickpapp's Avatar
Default fastener questions - trunk area
I am in the process of putting Dynamat sound insulation in my Base MT. When I pulled out some trim I came across this bracket that seems to do nothing. Also the 4 bolt holes in the rear of the speaker enclosure trim piece were not fastened down. Seems like they had been at
one other time. PO had no recollection.
Any advice appreciated. Pic attached.
TIA.
Old 11-21-2020, 12:45 PM
karlt
karlt's Avatar
I'm not sure about the empty holes, but the bracket is used to fasten the top strap on a child sear.
Old 11-21-2020, 01:06 PM
nickpapp
nickpapp's Avatar
Thanks for the reply, I will have to check the trim I removed, but that bracket was buried under plastic trim pieces rendering it inaccessible.
Old 11-21-2020, 02:35 PM
Bmsluite
Bmsluite's Avatar
Those should be held down. Dude before me was right about those brackets. They are for a child seat. You can ditch them if you want.
As for the fasteners, I bought this little kit off Amazon for $20. It has 16 of the most common sizes. You can replace all the fasteners in the whole car if you want to. And your friends cars. Should be in every DIYers shelf
nickpapp (12-28-2020)
Old 11-22-2020, 06:12 AM
nickpapp
nickpapp's Avatar
Thanks for the reply. I will be picking up a similar kit shortly.
Jacob Farmer
08-16-2020 10:47 AM
Deception
04-12-2015 06:09 AM
AreYouAMac
350Z Roadster
25
03-26-2008 11:50 PM
djnc
10-27-2005 11:03 AM
cwerdna
05-30-2004 03:54 PM
Quick Reply: fastener questions - trunk area
