Drifting - new clutch - need to improve master and slave cylinders?
Old 12-15-2020, 11:22 PM
patdriver
patdriver's Avatar
Default Drifting - new clutch - need to improve master and slave cylinders?
Hi,
i would like to have your opinion please, if you do drifting with your z regularly :
My z is a 2004 model, 280 hp, with brembo brakes and vlsd. I will use it on track very often, for drifting. I will do many mods on the chassis, and i ll put the nismo gt diff. I will add power soon too (400 hp with a compressor).
my question is about the hydraulics linked to the clutch : i will put a new clutch (czp stage 2), i will change the master and slave cylinders at the same time. Do you think the oem ones would be ok for a rather hard using in drifting? Or is it better and really advised to put the reinforced master and/or slave cylinders? Like the ones from z speed performance/willwood for instance. They are 4 to 6 times the price of the oem...😅
thanks in advance,
regards,
patdriver
Old 12-16-2020, 08:29 AM
epenbecks
epenbecks's Avatar
280 hp? nice
Do you drift often?
Old 12-16-2020, 10:11 AM
jdmfetish
jdmfetish's Avatar
Tilton Clutch Master Cylinder Best Solution
patdriver (12-17-2020)
Old 12-16-2020, 10:36 AM
iideadeyeii
iideadeyeii's Avatar
Originally Posted by epenbecks
280 hp? nice
Do you drift often?
He's accounting for compression loss due to mileage. Respect
Old 12-17-2020, 09:11 AM
terrasmak's Avatar
Received 2,316 Likes on 1,667 Posts
Stock master and slave are great, the weak point of the system is the flexible rubber line that you will also replace with braided steel. When you replace the line, make sure it gets wrapped in heat shielding, use Dot 4 fluid and enjoy troublefree years from the system .
Old 12-17-2020, 12:55 PM
patdriver
patdriver's Avatar
hi, thanks for your answer.
which line are you talking about ? The reservoir hose or the clutch hose?
regards
Old 12-18-2020, 06:51 AM
iideadeyeii
The line that goes to the slave.
My only problem with the factory line was on a dyno. It overheated and I lost pressure
patdriver (12-18-2020)
Old 12-18-2020, 11:58 AM
patdriver
patdriver's Avatar
Ok thanks very much.
orion445
06-02-2014 10:50 AM
Rev_Night
04-08-2014 01:51 PM
350z>S2k
08-28-2012 12:50 PM
Kyle R
07-06-2011 03:37 PM
JasonZ-YA
Drift
12-08-2008 07:13 PM
Quick Reply: Drifting - new clutch - need to improve master and slave cylinders?
