Problems after Rear main seal change.
Old Feb 14, 2021 | 08:56 AM
Brock Lee's Avatar
Brock Lee
Default Problems after Rear main seal change.
I have a 05 350z with 300k miles.
Changed the rear main seal now
1. Car takes too long to start
2. No power when u floor it very slow acceleration.
3. Misfiring
The mechanic says he has fixed the flywheel properly by aligning it to that marking and everything.
he also tried positioning/aligning the crank sensor multiple times but cant find the fault.
Old Feb 14, 2021 | 10:03 AM
travlee's Avatar
travlee
Master
3. Misfiring
Did you scan for codes? A Nissan mechanic, or some mechanic is an industrial strip garage?
Old Feb 16, 2021 | 06:09 AM
Brock Lee's Avatar
Brock Lee
The codes said the crank sensor was bad. Changed it today and im still getting the same problem.
Old Feb 16, 2021 | 07:21 AM
travlee's Avatar
travlee
Master
Use nissan sensor?
Old Feb 16, 2021 | 08:46 AM
i8acobra's Avatar
i8acobra
Aftermarket flywheel or factory? Aftermarket flywheels have two alignment holes. One for FWD applications and one for RWD.If you accidentally use the FWD hole, you get crank sensor codes and no power.
z33cole
Dec 9, 2019 05:07 PM
Nismo909
Sep 24, 2014 05:03 AM
slipknot2157
May 30, 2011 04:24 AM
phunk
Mar 16, 2008 08:17 PM
turboex
May 26, 2005 11:12 AM
