2003 Valve Cover Gasket
Old Feb 15, 2021 | 04:16 PM
Stico's Avatar
Stico
Default 2003 Valve Cover Gasket
When replacing the valve cover gasket I see majority of posts say to replace covers complete, however I see gasket kits with coil o-rings....not having done this job before what is the issue with re-using existing covers?
Thanks!
Old Feb 16, 2021 | 06:13 AM
The_Laughing_Man's Avatar
The_Laughing_Man
It's highly recommended to change the actual valve cover along with the gasket. The valve cover has seals around the spark plug wells to keep oil out of them but they degrade over time. If you're going to take the thing apart for the gaskets just do the covers as well. There should only be 4 parts you need: 2 valve covers, 2 valve cover gaskets. Buy OEM if you can, they are expensive but people have had issues with cheaper alternatives.
Old Feb 16, 2021 | 03:25 PM
Stico's Avatar
Stico
Thanks. Don't I need the plenum gasket too?
Sorry for all the questions, but my history is with Saabs and this is the first 350Z for me.
SC
Old Feb 17, 2021 | 05:20 AM
The_Laughing_Man
SC
You could certainly replace the plenum gasket after you take it apart for this job.
Old Feb 17, 2021 | 07:34 PM
icer5160's Avatar
icer5160
Hi Stico,
I found this post regarding the valve covers and the spark plug well seals. The OEM baffle plate is the main reason people just purchase new covers. For one reason or another, Nissan decided to make the baffle plate in such a way as to prevent easy replacement of the O-Ring/Grommet seals for the spark plug wells. The plate appears to be permanently glued in place. Another reason for replacing the cover is because of the chosen material. Over time these plastic valve covers can warp, causing continued leaking problems even after replacing the seal. I miss the days when quality materials were used in areas like this. I did a valve cover job on a 1999 4Runner, both valve covers were aluminum as well as the entire intake manifold + plenum assembly.
Luckily this issue is relatively minor and a set of new covers should last over 100k miles.
Cheers,
-Icer
VincentMicah
Mar 31, 2020 10:56 PM
San Cheech
Sep 1, 2019 05:01 PM
bikinilust
Apr 4, 2012 08:35 PM
Mr_pharmD
Jan 22, 2008 07:12 AM
