O2 Sensor Codes
Old Apr 2, 2021 | 09:48 AM
A_Mini_Max's Avatar
A_Mini_Max
Default O2 Sensor Codes
My 350Z is throwing O2 sensor codes because of the test pipes on it, what is the best way to get rid of this? Some people have told me a tune could do it and others have told me I need to buy a fake O2 sensor that mimics correct readings.
Old Apr 2, 2021 | 10:13 AM
WYZIWYG's Avatar
WYZIWYG
Just buy some 02 sensor bungs online or from any auto parts store.
Old Apr 2, 2021 | 10:55 AM
A_Mini_Max's Avatar
A_Mini_Max
what do I do with said bungs to fix the code?
Old Apr 2, 2021 | 01:56 PM
The_Laughing_Man's Avatar
The_Laughing_Man
You need extended bungs that will increase the distance between the sensor and the exhaust, tricking the car into thinking there are cats. You might be able to find threaded bungs that you can install in the existing one, or you'll have to have some welded in.
Old Apr 3, 2021 | 03:10 AM
139driver's Avatar
139driver
Default Upstream or downstream codes?
What codes are you throwing? I have test pipes on my 2006 and it’s throwing the upstream codes- not the post cat codes....
Old Apr 3, 2021 | 11:38 AM
A_Mini_Max's Avatar
A_Mini_Max
I would have to double check the codes but I believe it is the downstream ones.
Frostydc4
May 11, 2022 07:14 PM
Zena8956
Jul 28, 2020 10:08 AM
Sheasta
Aug 20, 2013 12:54 PM
SkyZ33
Oct 16, 2012 07:59 PM
DJMatrix1067
Jan 1, 2007 06:11 PM
