Track Front Tow Hook with License Plate
Old Apr 8, 2021 | 11:29 AM
Sundown72's Avatar
Sundown72
Default Track Front Tow Hook with License Plate
General question for people who track their Z:
The series I’m running in requires a tow hook. The car is also a street car (to/from the track) with a front license plate (also a class requirement).
Does anyone know of an offset tow hook mount for the 350Z? Or if you’re doing something else, what’s your solution?
Thanks.
Old Apr 8, 2021 | 12:00 PM
terrasmak's Avatar
I ran my stock tow hook and no front plate
Old Apr 8, 2021 | 01:13 PM
Heel Til I Die's Avatar
Heel Til I Die
You could always relocate your front plate.
Something like this:
Old Apr 8, 2021 | 06:55 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Nah- don't drill your bumper any more. Just zip tie the license plate frame lower and to the side in the radiator opening (are you sure your track really needs this?) and run an aftermarket/OEM tow hook in the center slot.
Old Apr 9, 2021 | 04:39 AM
Heel Til I Die
That was just an example of relocating the front plate. There are no drill kits available like this:
Old Apr 9, 2021 | 06:57 AM
Sundown72's Avatar
Sundown72
Thanks for the feedback, all.
The tow hook is a series requirement, and a good idea generally for track cars. My class requires the car be plated and insured for the street, and I’ll be driving it to and from local events, so the plate is also a need.
Moving the plate further into the grille opening isn’t really an option, I’d like to avoid compromising the cooling.
I’m thinking I’ll likely get a tow-hook plate mount and just swap it at the track for the tow hook.
Thanks again.
Old Apr 9, 2021 | 07:39 AM
350ZXLR's Avatar
350ZXLR
Check the rules again and ask for clarification (then please post the result). "For the street" might just mean registered and drivable on the street but you should be able to remove the front plate for the track since it's private property. It sounds like the organizer is just trying to simplify enforcement of the street-legal class spec. If you can show them the second license plate, then they should be happy. I'd be concerned about blocking the airflow and they should understand that.
Old Apr 9, 2021 | 08:36 AM
rancor's Avatar
rancor
I put some riv-nuts, designed for plastic, in the bumper and remove the front license plate and holder and install the OEM tow hook. Thats been fine with the two groups I've done track days with. If you really do need the plate the side of the grill option is probably best to keep it on the front of the car. About 4" of the grill on each side are blocked off on a stock Z so your not reducing your intake area as much as you think. Also just through of windshield plate mounts but again only if its needed and allowed.
Old Apr 9, 2021 | 01:28 PM
Sundown72's Avatar
Sundown72
Thanks again for the replies. I think there’s been some confusion. The front plate doesn’t have to stay on while on track, I was just hoping to avoid having to swap back and forth.
Seems like the swap is the way to go, so I’ll be taking the plate off and putting the hook in while at the track.
Old Apr 12, 2021 | 06:36 PM
350ZXLR's Avatar
350ZXLR
Indeed. From the OP:
This wording makes it sound like running street legal with a front license plate is the class requirement.
It sounds like rancor has the answer. I don't have a stock front splitter so can't check the airflow, but it's encouraging to hear that there's a place without airflow that the plate can reside.
Old Apr 17, 2021 | 05:55 PM
Dan Garcia's Avatar
Dan Garcia
i built my own bracket for a benen tow hook, have not taken the time to bolt it yet because i have no dead lines, one of these days when i have to remove the bumper i will run the bolts.
subzeros
May 4, 2007 08:15 AM
nokidz
Aug 21, 2003 08:38 AM
shoalhaven
Jan 30, 2003 01:05 PM
Bobby C 01TA
Nov 30, 2002 05:26 PM
