Clutch slipping?
Old Jun 7, 2021 | 06:45 AM
139driver's Avatar
139driver
Default Clutch slipping?
Changing gears from 4th to 5th ( did put my foot down )while getting in the freeway and at 60mph I noticed that my speed stayed at 60 but my RPM just kept climbing…
Is this the beginning of my clutch going out?
Old Jun 7, 2021 | 09:41 AM
dkmura's Avatar
dkmura
General & DIY Moderator
It would help to know how many miles are on your Z, or at least how many since your clutch was last replaced? Without that, I'd simply guess yes.
Old Jun 7, 2021 | 01:46 PM
139driver's Avatar
139driver
Bought the car in January and it now has 115k miles on it- got it from a used car dealer so no idea as to when and if the clutch was last worked on….
seems to shift fine through all the gears if driven slowly, but as soon as I accelerated hard from 4th to 5 th gear - the speed stayed at 60 and the rpm just kept climbing til I backed off the throttle.
Old Jun 7, 2021 | 01:47 PM
travlee's Avatar
travlee
Master
My bet would be yes. When you replace it, I would also do pivot ball, clutch fork, and slave cylinder
Old Jun 7, 2021 | 08:55 PM
terrasmak's Avatar
Pretty common, time to replace it
Old Jun 8, 2021 | 05:59 AM
iideadeyeii's Avatar
iideadeyeii
Put it in 5th around 3k and floor it. If it slips then the clutch is slipping. Clutch can be done on jack stands in about 4 hours. Get a lot of extensions. This is the clutch I went with on my Z with ~ 300whp 335wtq https://www.ebay.com/itm/13265692549...QAAOSwy2Ncw5F-
Didn't break it in and I have been beating the hell out of it.
Old Jun 8, 2021 | 12:37 PM
icer5160's Avatar
icer5160
Clutch almost without a doubt. I've experienced the same sensation from a failing clutch in the Z. For the briefest of moments I thought my rear tires were losing traction when the RPMs shot up.
-Icer
Old Jun 14, 2021 | 01:46 PM
Makriluc's Avatar
Makriluc
Are you truthfully using this non expensive clutch kit? Did you mount this to your original Dual Mass Flywheel?
Old Jun 15, 2021 | 06:25 PM
Subd's Avatar
Subd
what year is your nissan I know that the 03s had stamped forks, might be bending in higher gears, most likely clutch
Old Jun 17, 2021 | 05:57 AM
iideadeyeii
Yes, I bought this off eBay for about $60 shipped. I installed it with the factory dual mass stock flywheel without refinishing and just lightly sanded it with 400 grit paper. I am running a godspeed turbo kit @6psi. I also forgot a pressure plate bolt when installing and haven't had any issues. I always shift very hard from 1st to 2nd
The number on the "stage 1" clutch disk is just an oem replacement disk. The pressure plate number didn't seem to get me any info online
I also skipped the top driver's side bolt on the tranny because it's a PITA to get to
espitia350
Sep 2, 2017 02:05 PM
Nexx
Feb 6, 2008 07:46 PM
kensin0429
Nov 2, 2006 12:57 PM
Riggz
Jul 27, 2006 11:03 AM
kewlii
Dec 6, 2004 09:13 PM
