Unknown connector
Old 12-06-2021, 01:49 AM
SultnOfSubmsion
SultnOfSubmsion's Avatar
Default Unknown connector
I recently replaced my flywheel, clutch and pressure plate on my 2008 nissan 350z and when i was putting everything back i cannot find what goes in this connector. These two connections are located right next to the starter, i could be completely dumb and overlooking it. Any help would
be greatly appreciated.
Old 12-07-2021, 08:07 PM
icer5160
icer5160's Avatar
I honestly don't recall, it looks like a two-wire plug, so perhaps passenger front ABS sensor? You seriously don't have a hanging plug tucked away somewhere? Perhaps the HRs are different, but when I did a clutch job on my DE, the majority of the harness connections I had to move were for the transmission.
-Icer
Old 12-07-2021, 08:10 PM
SultnOfSubmsion
I dont have any wires hangin off tht i can see, it is a 2 wire plug. Yea the only ones i had to remove was the ones wrapped around the trans. Idk maybe it doesnt have anything but for the life of me i cant figure it out lol
Old 12-08-2021, 02:54 AM
Heel Til I Die
Heel Til I Die's Avatar
Received 1,096 Likes on 776 Posts
Just a guess, but I think the only other connections around that area are for the back-up lamp switch and the PNP switch.
Old 12-08-2021, 03:45 AM
SultnOfSubmsion
Both of those are connected, these 2 connectors are up by the front of the trans where the starter hooks up
Old 12-08-2021, 05:42 AM
SultnOfSubmsion
Idk if this will help any but here is a shot from the back of the trans lookin towards the front. The 2 connectors are right in front of the slave if tht helps any
Old 12-09-2021, 12:49 PM
icer5160
icer5160's Avatar
So that's the driver's side then? Unless this is a JDM model. Again HRs may have done things different here, but the starter should be on the passenger side. I recall the crank position sensor being in that area, other than that, there's the O2 sensors.
-Icers
Old 12-09-2021, 05:47 PM
SultnOfSubmsion
It is not a jdm model (although i wish) it is on the drivers side, all the o2 sensors are plugged in, ill double check but im pretty sure the crank sensor is also
Old 12-09-2021, 06:10 PM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,285 Likes on 2,337 Posts
My first thought was crank position sensor but there's no mention of the car not running or not running well which would certainly be the case if the cable was detached.
Old 12-09-2021, 06:14 PM
SultnOfSubmsion
Yea the car runs fine, no issues tht i can tell immediately
Rybear458
Drivetrain
01-20-2017 02:01 PM
TapTap350z
10-28-2013 04:17 PM
JustinTime
Drivetrain
12-18-2011 05:55 AM
Quick Reply: Unknown connector
