2006 Nissan 350Z
Old Dec 13, 2021 | 05:18 PM
ErickBurleson's Avatar
ErickBurleson
Default 2006 Nissan 350Z
So I have a question… my 350Z has had a quiet ticking, not loud at all so I did not think it was anything too serious. It kept doing it, my friend told me that it was an injector tick, which was normal so I didn’t pay it any attention. Well it kept doing it, worse on a cold start, so I thought maybe it was because I needed my oil changed, maybe the oil lost it’s viscosity and needed to be changed, but once I got the oil changed and left, it continued. Was driving the speed limit which was 55, the ticking got significantly louder, and faster, it kept getting louder, almost seemed like I was losing power a little bit, but I could still accelerate, but due to me being worried I turned my hazards on and drove slow, and even driving slow the ticking got louder, and then it felt like a combustion, almost like I was jerked in the car, but I checked my rear view and nothing came out from underneath the car, the car was running, but the gas pedal didn’t work AT all, it felt normal as far as stiffness, but didn’t rev, or nothing, it literally did NOTHING, I lost all power steering, but all of my lights and stuff worked, literally all I could do at that point is man it over to the side of the road and brake, literally could only break in that car, since then I have tried to turn it over, all lights and everything are working even the radio in the car is working, but it won’t even turn over, it does NOTHING, except a little click that sounds like a battery, but it’s not the battery… cause everything else works… i took a socket and tried to spin it to see if the motor was locked, and couldn’t spin it, so don’t know if I wasn’t spinning it hard enough or what, but I need someone that is mechanically knowledgeable to help me out!
Old Dec 13, 2021 | 06:39 PM
jhc's Avatar
jhc
General & Tech Moderator
#1- Check your oil level on flat ground. If you see any oil on it there's hope.
#2- If you're gonna try to rule out a locked motor put a brick/stone behind the wheels and put the shifter in neutral. Gl!
Old Dec 13, 2021 | 07:24 PM
AxionZ's Avatar
AxionZ
The car is throttle by wire so if the ecu is ignoring the pedal input the car won't respond. How much time/miles elapsed from when you first noticed it? Might have to drop the oil pan.
Old Dec 14, 2021 | 09:50 AM
icer5160's Avatar
icer5160
Do #1, #2 couldn't hurt either if you're attempting to turn over engine with crank pulley bolt.
Regarding the starter click, this is usually caused by a dead battery. But after reading your post and what you're describing. It sounds like your engine is locked up. I assume the battery is good and the starter was working perfectly fine earlier that day. Event sequence recap...Started with quiet ticking, turned into loud ticking, then knocking, followed by loud bang noise, resulting in engine stalling/quitting and unable to restart (turn-over).
If you're not able to diagnose this yourself, have mobile mechanic have a look if you can't afford to get it towed to a shop.
Good Luck!
-Icer
Old Dec 14, 2021 | 12:21 PM
ErickBurleson
Checked the oil today on flat ground, and it was full, right where it needs to be. So put a brick behind the back tire, and put it in neutral what does that do?
Old Dec 17, 2021 | 07:24 AM
jhc's Avatar
jhc
It keeps you safe so you can place a 22mm (?) socket on the crank pulley bolt and turn the engine over by hand to rule out engine-seize.
Old Dec 26, 2021 | 07:49 PM
Syner's Avatar
Syner
Jesus. This read like a meth-fueled ramble.
*checks location
Par for the course right there, buds.
Old Dec 29, 2021 | 07:17 PM
g0lfball3R's Avatar
g0lfball3R
so that’s what that auto trans “stalling” was about. I just took over an 08’ hr w/ auto & had it stall & just restarted in park. Gave up an 06 revup m/t over worsening oil consumption & crappy treatment by previous owner.
broom n mop
Jan 21, 2016 03:44 PM
CerealIsAmazing
Nov 27, 2014 01:09 PM
bbongR
Apr 1, 2014 02:23 PM
wlshaw1
Mar 15, 2012 10:28 PM
