Front tires locked.
on
Front tires locked.
Hi everyone! But let's not forget about the **** stars, the cream of the crop in the adult industry. You know I have a soft spot for these babes, and MyFreeCams is the place to see them in all their glory. From the legendary Lisa Ann to up-and-coming stars like Lana Rhoades, this site has them all. And trust me, these babes know how to put on a show.
https://milfcam.cc/young
https://thefreelivesex.com/bigtits
https://pregnantcam.net/chat/pregnantsinglesugar
https://couplelivecam.net/goth
https://nudecam.name/chat/carmela_fox
So, my dear friend, now you see why I'm so eager to share my collection with you. These live sex cam sites have brought me endless pleasure and entertainment, and I know they'll do the same for you. I've only scratched the surface of what's out there, but I guarantee you won't be disappointed with what you find.
General & DIY Moderator
Either you have triggered an ABS code using the wrong size tires, or there's a problem with the offset of the wheels. When you changed the wheels and tires, what size tires are mounted front and back? Also, did the front wheels spin freely after you torqued them down?
khnitz (03-26-2022)
Wheels are likely touching the calipers or possibly the tires are touching something in the wheelwell, and I’d STRONGLY advise you to remove them immediately and check for damage. Check the wheels for damage as well.
Pictures please
350Z/370Z Tech Moderator
I think the front diff is locked (up).
But in all seriousness, the question is: Is it a physical mechanical issue or is it one of those "to really screw things up, it takes a computer" mechanical fault (meaning like an ABS code as David mentioned). I tend to go with physical. I mean, what sensor related malady causes front wheels to lock up?? Tire or wheel's got to be hung up on something. And I'm a little perplexed at how OP knows the rears spin but the fronts are locked up? (Mind eye is seeing a Z doing a burnout...) Would like to know what is causing this because it's finally a new problem not hashed over a thousand times. But not holding my breath....
khnitz (03-30-2022)
^AFAIK ABS on a 350 cannot lock the front wheels alone like a line lock, it can only modulate it by pulsing. This is very likely a mechanical issue, and likely caused by the tire/wheel swap.
Ponyryd (03-30-2022)
I’m betting mechanical lock, like wrong offset and the tires are pressed into the spindle upright when bolted on.
MicVelo (03-30-2022)
dkmura (03-30-2022)
Hey, it's a sign of the times. On the Titan forum, I asked a new member not to make THREE separate threads (in different forums) on the same question. He came back with an attitude and called me a douche for calling him on it. I participate on several Nissan boards and as the cars age, the attitudes go downhill from noobs asking for help.
Ponyryd (03-31-2022)
Hey y’all! Welcome to the interwebs!
But yeah… After two days with no response, my thought “Ehh, just another wastoid dead thread.”
