HELP Engine making screeching noise when start up
Hi all! so I got a used motordyne plenum spacer the other day and I saw the preattached gasket was damaged so I took it off and made my own with RTV. I torqued it down to spec and waited 24 hours for it to cure and then reset my ECU and I try to start it up. When I start it up it makes an extremely loud pulsing screeching noise. Idk what it is and I am very concerned it also smells like gas when I start it up. I changed my belts not too long ago so I don’t think it’s my belt. I’m worried pls SOS
Sounds like you have a bad vacuum leak somewhere, and possibly a fuel leak if you smell fuel as well. Run the car and try to pinpoint the leak, spray some WD-40 where you hear the noise and listen for an idle change, or the noise to stop, that will be the problem area.
I have the Z1 plenum spacer gasket but I wasn't sure if it was safe to use bc it’s skinnier than the spacer but when I start up my engine when it’s warm it doesn’t squeal anymore, only when it’s cold any ideas with this info?
Well it could be that the metal warps into a sealed shape at a very small level? im not sure but i mentioned this https://www.z1motorsports.com/manifo...et-p-5371.html , gasket which is different for the one on the plenum spacer but just make sure everything is tightened right
okay final update I fixed the tensioner when it was cold and then I started it and the squeak was gone so it was my belt! Thank you for the help
cipher
May 19, 2009 08:23 PM
