Wallbro 255 Issues ?
Old May 1, 2022 | 05:10 PM
NapZzZz's Avatar
NapZzZz
Default Wallbro 255 Issues ?
I recently installed a Wallbro 255 because my OEM fuel pump was dying. I purchased this a long time ago because I was thinking about going FI but am no longer doing so. The issue I am having is it only starts 1/4 of the time. I can here the pump prime, I will let it finish priming as it takes a couple seconds. Most of the time its just crank, even if im giving it gas while doing so. After it starts it runs fine. I did not make the regulator any bigger, so it should be running the same fuel pressure id imagine. One of my friends suggested changing the fuel pump relay. Before I go and buy one, I wanted to post on here to see if anyone has had similar issues, or if there are other issues that are more likely.
Old May 2, 2022 | 10:48 PM
bealljk's Avatar
bealljk
I’ve sworn off walbro as brand that I will never install in any car I run. I think I had 4 or 5 of them fail on me in the past 3 or 4 years in multiple vehicles with a variety of fuel system setups.
Old May 3, 2022 | 12:07 PM
NapZzZz's Avatar
NapZzZz
I really hope that is not the case, but I guess it is an area I should check.
Old May 4, 2022 | 12:45 PM
RENFRO's Avatar
RENFRO
Sad to hear that. I ran a walbro 255 for 6 years without an issue on factor wiring. Currently on a walbro 450 on a boosted setup without an issue too.
Old May 10, 2022 | 12:24 PM
Sundown72's Avatar
Sundown72
Grab a multimeter to check the fuel pump control circuit before you start throwing parts at it. IIRC the fuel pump signal is the yellow/black in the 5-pin plug on the fuel sender unit. The ground is the solid black.
(Again IIRC, the other three are fuel level to unified meter, fuel level from driver side level sender, and fuel temp to ecu…but that could be wrong. Check the FSM Power and Ground section to confirm).
You can get all the relays in the IPDM (including the fuel pump relay) independent of buying a whole unit. Give a forum search for the part numbers. They’re reasonably affordable.
If the pump is priming though, I’d be more concerned with no crank sensor signal, especially if it doesn’t react when you open the throttle (usually the solve for an overly-rich starting condition).
After that, maybe clogged injectors? Maybe?
Good luck, let us know how it goes.
Old May 10, 2022 | 01:18 PM
jhc's Avatar
jhc
General & Tech Moderator
Good over here, about 18 months.
JuanGarzaro
Jul 21, 2020 04:30 PM
Sup Fresh
Oct 22, 2016 03:40 PM
imanator
Jul 17, 2013 04:09 AM
accordfreak
Dec 12, 2009 03:58 PM
moog
Jun 9, 2009 08:00 AM
