Wheel fitment
Old 06-01-2022, 07:04 PM
Ethen
Ethen's Avatar
Default Wheel fitment
So I’ve been looking at a lot of tires, wheels ect. I also want to mention I went in depth with wheel measurements and wanted to know if 18x10.5 an 22 off set will fit all around with 255 In the front and 265 in the rear ? Just want to know if I would see any rubbing or clearance issues with this set up. I also am at stock ride height.
Old 06-02-2022, 08:21 AM
terrasmak's Avatar
Received 2,314 Likes on 1,666 Posts
With 40 series tires, they will fit
Old 06-02-2022, 10:32 AM
Ethen
Ethen's Avatar
Okay so what if I wanted a square set up ? will 18x10.5 fit all around with 265 all around ? Stock suspension?
Old 06-03-2022, 08:18 AM
terrasmak's Avatar
Front may require added camber to clear with a 265/40 , no big deal
Old 06-04-2022, 08:37 PM
Ethen
Ethen's Avatar
Ok so you say a little camber in the front. Wanting to run 265/40/18 18x10.5 all around I think rolling my front fenders will do the trick instead of adding camber don’t you think it will too ?
Old 06-05-2022, 06:38 AM
travlee
Master
travlee's Avatar
Received 9,126 Likes on 6,579 Posts
Front are already rolled from factory
Old 06-06-2022, 04:21 AM
terrasmak's Avatar
with a 265/40 up front, you will probably end up adding a little camber and minor pull of the front fenders
Old 06-07-2022, 11:24 AM
icer5160
icer5160's Avatar
If they will fit, I would go 275/40 for a more squared off sidewall in the rear, otherwise things will look pretty stretched. I'm running 275s right now on 18x9.5 +30 on the rear, and 245/40 on 18x8.5 +25 in the front. At least with these specs, I don't have any clearance/rubbing issues but still maintain a very flush fitment. Stock suspension all around. I know your width & offsets are different, which could make or break things, but still close to what I'm doing. I have been able to run 19x10 +30 wheels in the rear on 275/35s without issue, but I've never gone beyond that.
Cheers!
-Icer
Ethen (06-22-2022)
Old 06-22-2022, 02:21 PM
bre240z
bre240z's Avatar
Just got these on a week ago front18x9.5 +15 255/40/18 rear 18x10.5 +20 275/40/18.
Car has TEIN Basis coil over. Have not rolled the rears yet since i havent heard any rub. Im thinking once i take it up to the canyon i will have some rubbing. I plan to roll the rears regardless.
Stock UCA up front on the rear i do have spc camber arms and toe bolts. I probably should get the car aligned again even though i had one done 2 months ago when i first installed the coilovers and lowered the car.
Ethen (06-22-2022)
Old 06-22-2022, 05:38 PM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,285 Likes on 2,337 Posts
Nice setup. Very nice fitment.
Y'know, you might not need to roll the rears. Where you'll hear noise isn't so much hills/track. It's those damm speedbumps in parking lots. Keep watching/listening. I didn't have to roll until I went down to +15 (and that was a modest bit of rub). But gotta say - A roll helped a lot for as often as I was changing up my wheels. I run my 19x10.5s at +8 along with 285/35s.
Old 06-23-2022, 10:48 AM
bre240z
bre240z's Avatar
thanks for the input. I honestly dont really want to roll the rears. Yea the only time i really hear anything in the rear is when im going into a gas station or driveway some times but not always. Might just roll like this for now and feel it out
jlz33
03-17-2011 03:31 AM
Spork
08-26-2007 08:34 PM
mrtomcat
10-16-2006 08:35 PM
w8lifter21
09-30-2005 01:37 PM
Quick Reply: Wheel fitment
