350z revup to de swap. ECU (NATS) question
Old Dec 23, 2022 | 06:27 PM
Kassi.k24's Avatar
Kassi.k24
Question 350z revup to de swap. ECU (NATS) question
So I am ab to swap my blow 350z revup engine (2005 35th yr anniversary) with a non revup 04' de engine. I've been seeing that you need to change the ECU (which I know I have to) to a de non revup ECU and get the NATS flashed off.
I came across this website that says if I send them the VIN of my car they can make an ECU that is plug and play and send it to me, I'm wondering if I just get the ECU from this website if I can avoid having to buy an ECU and then paying to get it flashed. Will this work? hope I explained it well enough. !!! the Ecu from the website is a 04' de !!!
Website for context:
https://www.fs1inc.com/23710-ce805-2...SABEgI5ofD_BwE
Old Jan 9, 2023 | 08:39 PM
Sundown72's Avatar
Sundown72
Just pull the heads and plenum off your RevUp and put them on the DE. You can save the $ and hassle of the ECU and you can do the timing chain, tensioners, guides, RevUp oil pump, galley gaskets, and water pump while you’ve got the new engine out of the car anyways.
ace32x
Apr 6, 2023 07:31 PM
theZride03
Aug 12, 2017 08:22 PM
SexyRob
May 21, 2017 10:26 PM
bbs350z
May 16, 2013 08:12 AM
G35-31
Sep 30, 2009 02:00 PM
