2006 Nissan 350z over heating
Ok so my z will drive for about 20-30 minutes and then will stop it will stay running but won’t go in any gear and won’t rev after 5 seconds of doing that it will try and go and will jerk back and forth back and forth I have to shut the car off for 5-10 minutes and then it will do the same over and over I took it to autozone to get the codes read and these are what pop up heater control circuit low bank 1 sensor 1 and heater control circuit low bank 2 sensor 1 does anyone know what I can do to fix this problem?
The O2 sensor heaters have a fuse. If both are showing "low" it's probably a blown fuse. The sensors could be bad, but it's unlikely for both sensors to go bad at the same time. Fix that first, then report back. Also, your topic title says "overheating" but you made no mention of that in the body of your post. Is it overheating? Is the coolant in the reservoir boiling? Is the gauge pegged all the time, or after 30 minutes of driving? You need to include a LOT of info in your post if you expect an accurate diagnosis over the internet.
I was told it was overheating I’ll be driving it like when I go to work or something and like 10-15 minutes when it gets warmed up it stops car stays running but if I put my foot on the gas it won’t do anything at all I’ve replaced all my o2 sensors but still don’t know why it’s doing this I even cleared the codes and when I did that the engine light stayed off today but 10-15 minutes down the road it does the same thing again
Enticed
Jul 12, 2019 07:29 AM
