03 350z loses power when accelerating over 4k rpm’s
Old Dec 2, 2023 | 03:03 PM
Lenny_z33's Avatar
Lenny_z33
Default 03 350z loses power when accelerating over 4k rpm’s
When driving the car, it’s likes to cut back on power and rpm’s go up super slow when the pedal is to the floor. Doesn’t happen all the time and is super weird. Changed fuel pump, spark plugs, put fuel system cleaner in the tank, new throttle body, new sensor at the gas pedal (not oem), new cam sensors and still has the same issue. Did notice the plugs for the cam sensor can slide out easily with just pulling it not sure if that can be it. Any suggestions
Old Dec 2, 2023 | 03:47 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Pull codes.
Old Dec 2, 2023 | 03:55 PM
Lenny_z33's Avatar
Lenny_z33
Originally Posted by MicVelo
Pull codes.
No active codes
Old Dec 3, 2023 | 04:44 AM
Aeneas137's Avatar
Aeneas137
you'll lose power dramatically like that when the ECU pulls timing in the engine to protect it. If it's bad enough, like a loose MAF sensor wire, then you'll feel it go into limp mode. that somewhat seems like what you're describing here. If those cam sensor plugs are very loose, ie the clips are broken, you could try wrapping the edge of them with a bit of masking tape so they fit more snuggly. or try to get a zip tie around them tightly.
Old Dec 3, 2023 | 07:43 AM
Lenny_z33's Avatar
Lenny_z33
I’ll inspect the wiring and zip tie the connectors together and drive it again and see what happens. Got a YouTube link of what’s happing :
Old Dec 4, 2023 | 04:08 PM
Lenny_z33's Avatar
Lenny_z33
Zip tied the connector and still have the same issue, I’ll order the connector pigtail to eliminate that being the issue. Other than that the car never went into limp mode or throw any kind of codes or lights on the dash. What else can I look at if the ecu sees something off that causes that cut
Old Feb 14, 2025 | 05:49 AM
Picsou14's Avatar
Picsou14
Originally Posted by Lenny_z33
I’ll inspect the wiring and zip tie the connectors together and drive it again and see what happens. Got a YouTube link of what’s happing : https://youtube.com/shorts/9cOu66d1R...e-Ia6l_c8kUC1x
did you solve the problem ?
Old Feb 26, 2025 | 09:23 AM
gavsis350z's Avatar
gavsis350z
Check your crankshaft position sensors both of them, i had the same issues with the ecu not showing lights or codes and replaced both sensors and started getting ECU codes for the misfire. I also replaced the Valve Timing Control Solenoids too.
Zack Miller
Apr 8, 2019 12:06 PM
DesertShadow
May 15, 2014 07:09 PM
Wesleez
Apr 10, 2014 03:43 AM
solidsnake
Jan 13, 2013 03:29 PM
POWERSLIDIN
Jun 24, 2009 01:03 AM
