Walbro 350 Install
Old 01-11-2024, 01:45 AM
channing2294
channing2294's Avatar
Default Walbro 350 Install
Hey Guys,
Wondering if anyone has done the install with a Walbro 350? I currently have the 255 but am putting together a newly built vortech DE and need more fuel.
Do you need to do any drilling in the orifice like the 255 or is it plug and play?
Cheers,
Channing
Old 01-11-2024, 07:40 AM
bealljk
bealljk's Avatar
Received 1,299 Likes on 1,023 Posts
The AEM 340lph and most the Walbro 340lph are direct replacements -
Do you have a return fuel system on the car? Or plan on getting one?
Did you already drill the orifice when you installed the 255lph?
channing2294 (01-11-2024)
Old 01-11-2024, 09:26 AM
channing2294
255 is currently installed with the drilled orifice. And yep, fuel return system and bigger rails.
Thanks for the reply buddy, I'll be popping the 350 Walbro in this weekend.
Im assuming the install is the exact same as the 255? The case looks identical. (Ex. Trimming the bottom plastic)
Cheers
Old 01-11-2024, 05:48 PM
bealljk
bealljk's Avatar
Yea - they are very similar - get in there and have a look -
If you have questions after you get in to it just let us know and we’ll help you out -
Old 01-11-2024, 05:51 PM
channing2294
Just finished the install. Exact same as the 255. Shaved the tabs off the bottom and it popped right in. Drilled the jet to .093". Hopefully that'll do the trick for the pressure. We shall see come initial start up in a few months time.
bealljk (01-15-2024)
SpoilsofWar
01-17-2008 03:05 PM
MUZZY
04-09-2007 02:23 PM
prescience
10-24-2005 05:09 AM
bwzabodyn
07-29-2004 06:56 AM
Quick Reply: Walbro 350 Install
