350Z - C1140 - ABS Accuator Relay Circuit Failure
Old Jul 3, 2024 | 05:56 AM
2004silverz's Avatar
2004silverz
5 Year Member
Default 350Z - C1140 - ABS Accuator Relay Circuit Failure
Hi, I have a 2004 350Z and all light came on in the dash - TCS, ABD, Brake, etc...Took it to a mechanic and he did a diagnostics and told me that the alternator is good and told me he got the C1140 code... Any suggestions please. Thank you!!
Old Jul 15, 2024 | 04:20 PM
icer5160's Avatar
icer5160
Your ABS module could be faulty or you have a wiring fault somewhere on the ABS harness. Check for corrosion, check power and grounds to the ABS module. Any signs of rodent intrusion in the engine bay? Any details on vehicle history?
I've never heard or seen a legitimate ABS module failure on a 350Z before, but I'm sure it's possible, just very rare. Most ABS related issues I've run across (all makes/models) are either directly related to a poor ground or power connection/supply (supply meaning battery or alternator) or wiring damage. The last one I ran into & repaired was wiring damaged caused by rodents nesting near the ABS module and those punks love chewing on wiring!
A standard code reader typically doesn't talk to the ABS system, this is a separate module from the engine or anything emissions related. The screenshot you shared even says it... "Emission Related Engine DTCs."
Cheers!
-Icer
Old Jul 16, 2024 | 06:52 AM
03stampededak's Avatar
03stampededak
The two times I've had to tow my 07 350z I've had abs modules that needed replaced. Maybe we didn't trace the issue far enough, but one of those diags came from a trusted Nissan mastertech. Both times I replaced the module with a used one as new ones we not available. No idea why.
sylixo
Oct 2, 2023 07:01 AM
Misaka_10032
Jun 17, 2016 02:57 PM
ZDominicZ
Aug 2, 2014 09:21 AM
350zflorida
Jul 14, 2008 09:51 AM
