AC question
Old Jul 7, 2024 | 01:26 PM
Plusdaddy's Avatar
Plusdaddy
Default AC question
So so I did a swap and the compressor calls for pag 46 but 350z manual says use klh00-pagso if u change condenser or anything like that .. I did put a new condenser and new AC lines . So can I just add pag 46
into system and the amount it says to give back oil to the condenser in lines or is klh00-pagso and pag 46 two totally different things? Any advice would be great .. thanks
Old Jul 8, 2024 | 12:33 PM
bre240z's Avatar
bre240z
I say just take it to a shop that specializes in AC. A reputable shop will use a specific machine that will evacuate and charge the system the right way. It can be pricey but if your not familiar or know what you are doing its best just to take in in my opinion.
Good luck
Old Jul 9, 2024 | 06:43 PM
Plusdaddy's Avatar
Plusdaddy
Appreciate the recommendation but I have the machine just not sure on the oil .. I did serval cars before but never did a compressor that didn’t belong to the car .. just wanted to know if I can add pag oil for everything or need that exact Nissan oil
Old Jul 11, 2024 | 10:05 AM
iideadeyeii's Avatar
iideadeyeii
EDIT nvm i have no idea. just use what nissan says.
I run 75/90 as 2-stroke oil in my weedwacker and it likes it. As long as it's oiled?
Old Jul 11, 2024 | 01:01 PM
icer5160's Avatar
icer5160
I think you can safely ignore what Nissan recommends since this is a complete AC replacement. I would follow the compressor mfg. specs. If the compressor MFG says PAG-46 is fine, with R134A, then use that. Note that most "new" compressors come from the factory pre-filled will the correct PAG oil.
Cheers!
-Icer
Old Jul 15, 2024 | 02:24 AM
LavonDavidson's Avatar
LavonDavidson
All good now?
Spoiler
Old Jul 30, 2024 | 10:05 AM
Plusdaddy's Avatar
Plusdaddy
Thanks everyone , yes it’s all set I did just sue pag 46 double end capped as the compressor manufacturer said and beeen good for couple weeks now
z33chance
Jun 4, 2022 07:33 PM
Ryan Jackson
Apr 14, 2018 06:14 AM
Bak3rme
Jul 18, 2016 09:17 AM
N4Spd
Oct 23, 2004 05:42 PM
