AC compressor
Old Jul 17, 2016 | 05:03 PM
Bak3rme's Avatar
Bak3rme
Default AC compressor
2003 350z.
I bought the car without the AC working. I found out a few months after I bought it that the AC compressor clutch fell off and was laying on my undertray when i did an oil change.
It now has been 3 years and i haven't really looked into fixing the issue but i recently was able to buy a used AC compressor (with clutch plate still intact) from a totaled Z for cheap.
question is...
is it as simple as pulling the old compressor off and putting the new one in? will it require draining the system of freeon and recharging it? can i just swap over the clutch plate?
thanks,
T
Old Jul 17, 2016 | 05:53 PM
dcains's Avatar
dcains
You need to hook up the new compressor, have the system evacuated and checked for leaks, and then have it charged with refrigerant. It's probably easier to swap compressers than install the clutch on the compressor mounted on the engine, but the compressor from the wreck may be an unknown quantity. Was the system charged when the co,pressor was pulled off,the wreck?
Old Jul 18, 2016 | 06:49 AM
Bak3rme's Avatar
Bak3rme
the compressor was working when it was pulled off from the wreck. I was not there when he pulled it off but some bright green stuff leaked out from it after he took it off. guessing its the freeon with color so you can pinpoint leak.
Old Jul 18, 2016 | 09:17 AM
dcains's Avatar
dcains
Then that's the compressor I'd use.
Gerry
May 4, 2016 05:28 PM
grr01gsr
Apr 12, 2016 03:18 AM
AboutTreeFiddy
Apr 8, 2016 07:15 PM
Red350956
Mar 28, 2016 09:15 PM
NUJOYZ
Jun 18, 2002 08:16 AM
