A.C. line is leaking
Old Apr 12, 2018 | 03:03 PM
Ryan Jackson's Avatar
Ryan Jackson
Default A.C. line is leaking
Recently bought and the a.c. line is leaking. Needing to know replacements and part numbers. First time owning a 350z. Anything will be helpful. Thanks.
Old Apr 12, 2018 | 03:35 PM
coletrickle74's Avatar
coletrickle74
Yeah there is definitely more than one AC line man. Sounds like you need to take it to mechanic.
Old Apr 12, 2018 | 03:36 PM
Ryan Jackson
Thanks man. I'll look around and see what my options are.
Old Apr 12, 2018 | 04:26 PM
Atreyu'z 350's Avatar
Atreyu'z 350
Welcome.. WHERE is your A/C line leaking?
Old Apr 12, 2018 | 04:32 PM
Ryan Jackson
It's leaking right under the guard for the cold air intake. My brother said it looks like it is coming from that particular part of the line. I'm not sure what I would need to get to replace it.
Old Apr 12, 2018 | 05:01 PM
Atreyu'z 350
Is the leak at a coupling connection, a seam weld, or in the middle of the line itself?.. Can you take a pic?
Old Apr 12, 2018 | 05:47 PM
Ryan Jackson
It's difficult to take a picture of as the leak is underneath the filter. But it does appear the leak is in the middle of the line.
Old Apr 13, 2018 | 09:08 AM
Atreyu'z 350
It would help to see the leak because depending on it's size and location will determine how it's fixed. There's flare couplings, epoxy, and then there's just replacing that section; all of which require the system to be evacuated of freon..
Old Apr 13, 2018 | 09:49 AM
iideadeyeii's Avatar
iideadeyeii
The rubber line part? Your info is bad and we are unable to help without an actual picture.
Old Apr 13, 2018 | 01:53 PM
Ryan Jackson
Old Apr 13, 2018 | 01:54 PM
Ryan Jackson
apologies. Still learning about the car trying to explain it best way I can. This should help. It's fairly apparent.
Old Apr 13, 2018 | 05:50 PM
vegasanthony's Avatar
vegasanthony
Ive used jb quick steel putty on those before worked well
If u want ro chage that hose ive got a used one dm me
Old Apr 13, 2018 | 07:05 PM
Atreyu'z 350
^ And there ya' go, OP. Thank vegasanthony.. Good stuff man.
Old Apr 13, 2018 | 07:11 PM
Ryan Jackson
Much appreciated. I order some of that putty to try it out. I will send you a message regarding the used hose. Thanks to everyone who helped me out with this.
Old Apr 14, 2018 | 06:14 AM
jhc's Avatar
jhc
General & Tech Moderator
When you recharge it might want to add dye. There are kinds visible in natural light and others visible under black light. gl.
Barzten1
Mar 10, 2009 05:52 PM
stewieisslow
Jul 16, 2008 08:53 AM
VIZAGE
Jun 6, 2008 08:06 AM
leeboyNY
May 3, 2008 10:34 AM
KarenZ
Mar 27, 2008 09:46 AM
