Side mirror
Old Dec 18, 2025 | 02:33 PM
OCMD's Avatar
OCMD
Default Side mirror
I cracked the right side door mirror. Where do I get a replacement and how hard is it to do? In addition, can I just buy the whole mirror mechanism? The paint on the current one is really faded and I'd like to replace the whole thing assuming I can get one in a factory color. I may be dreaming, but I don't know much about the replacement parts. Yet. THANK YOU.
Old Dec 18, 2025 | 03:12 PM
iideadeyeii's Avatar
iideadeyeii
You can get a whole replacement 350z mirror assembly (housing, glass, motor) from
CarParts.com or AutoZone or even a junkyard; it's a moderate DIY job involving removing door trim and swapping units, but finding one pre-painted in your factory color (find your paint code!) is the best bet for a seamless look, saving you body shop costs. Yes, you can buy the whole mechanism, and it's often easier to swap the whole unit than just the glass if the housing or motor is damaged or you want a fresh paint job. Where to Get a Replacement
  • Aftermarket Sites: CarParts.com, AutoZone, NAPA Auto Parts (check for 350z specific fitment).
  • Dealerships: For OEM parts, but pricier.
  • Junkyards/Salvage Yards: Great for finding a used, factory-painted complete unit in your color.
  • eBay/Amazon: Good for finding aftermarket or used parts, just check reviews and return policies.
This video shows you how to replace a side mirror assembly yourself:
How Hard Is It?
  • Moderate DIY: It's doable with basic tools. You'll remove the interior door panel/trim (often just clips and a screw) to access the bolts holding the mirror on, disconnect electrical connectors (power, heat, signals), unbolt the old, bolt on the new, and reconnect everything.
  • Check Your Paint Code: Look in the driver's door jamb or glovebox for the paint code (e.g., "KAD" for Gunmetal) to find a color-matched replacement, which saves big money on painting.
Buying the Whole Mechanism vs. Just Glass
  • Whole Assembly: Recommended if the casing, motor, or paint is bad. You get everything in one piece, often pre-painted if you're lucky.
Old Dec 19, 2025 | 04:59 AM
Heel Til I Die's Avatar
Heel Til I Die
^^^lol. AI-generated?
What part is cracked? The mirror glass, the part where it mounts to the door, or the exterior housing?
Post a pic or two.
Old Dec 19, 2025 | 08:45 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Bought an aftermarket powered/camera equipped and color matched unit for a friend/customer's Civic on Amazon. Took my tech all of 5 minutes to install - plug n' play. Perfect operation, great color match. Cost less than half of an OEM unit (which are usually aftermarket rebrands anyways.)
Like this unit (brand we used):
Amazon Amazon
Old Dec 19, 2025 | 10:32 AM
iideadeyeii
Old Dec 23, 2025 | 04:34 AM
IsidoreLockridg's Avatar
IsidoreLockridg
Spoiler
YouTube • Sep 6, 2021
How Hard Is It?
Thank you, you made my day. Merry Christmas
Old Jan 11, 2026 | 04:16 PM
OCMD's Avatar
OCMD
glass is cracked. housing is fine. i was told by a shop they cant replace just the glass.....
Old Jan 12, 2026 | 05:16 AM
Heel Til I Die
Find a new shop. That glass can be replaced. If you have heated mirrors, there is a flexible defroster plastic backing which is adhered to the back of the mirror glass. There are two wires that are connected to that. You can remove the defroster panel and stick it to the back of the new mirror glass. Use some new adhesive and stick the whole thing on the plastic frame mechanism that adjusts.
I did this on my Z when I swapped over to the Nismo multifunction blue tinted wide angle mirror glass. No more blind spots!
Here's a write-up using a similar mirror glass replacement (APR): https://my350z.com/forum/body-interi...lass-only.html
Diesel350
Interior
Mar 26, 2012 08:35 AM
Roper215
Sep 15, 2008 05:34 PM
Blk04G35Coupe
Jan 10, 2007 09:09 PM
