Need a good code reader that's semi modern
Old Mar 17, 2026 | 06:20 AM
Webbed350z's Avatar
Webbed350z
Default Need a good code reader that's semi modern
Good afternoon,
Looking for a good code scanner that is still supported and can read all the codes on my 2004 350z.
I tried Nisscan2 but seems outdated and also didn't work for me.
And not looking to spend £250+ on Z1 tool just yet.
Is there something out there that can look at everything on my car?
Kind regards
Old Mar 17, 2026 | 07:04 AM
bre240z's Avatar
bre240z
I been using this scanner for some time now. Nothing fancy but decent for the price. I got mine on amazon
Amazon.com: 2026 FOXWELL NT630 Plus OBD2 Scanner with ABS and SRS, ABS Code Reader Auto Bleed Scan Tool Brake SRS Scanner, Car Scanner Diagnostic Tool Bidirectional Live Data with SAS Oil Check Engine Light Reset : Automotive Amazon.com: 2026 FOXWELL NT630 Plus OBD2 Scanner with ABS and SRS, ABS Code Reader Auto Bleed Scan Tool Brake SRS Scanner, Car Scanner Diagnostic Tool Bidirectional Live Data with SAS Oil Check Engine Light Reset : Automotive
Old Mar 17, 2026 | 08:14 AM
icer5160's Avatar
icer5160
I personally have an XTOOL D8 that I purchased 3-4 years ago. It's already paid for itself after just a few uses to do electronic calibrations for throttle position relearns and an electronic brake booster replacement on a Toyota Prius. Xtool makes cheaper tools with similar feature support. I have used the D8 on my 2006 350Z to do throttle body position relearns after a deep cleaning and it worked without issue. I have also used it for general live data checks/diagnostics.
One that looks promising at a very affordable price point is the new
XTOOL D6S XTOOL D6S
for under $250.00. It supports a lot of special functions and has some nice live data options as well. It's not as advanced or feature rich as the D8, but for full system scanning and basic calibrations, it should do the trick. The Foxwell tool is also a good option, but I like having a touchscreen to navigate vs. a D-pad (so much faster/easier).
Cheers!
-Icer
Old Mar 17, 2026 | 03:41 PM
iideadeyeii's Avatar
iideadeyeii
I use this as well
Austin_14
Southern California
Aug 5, 2023 08:08 AM
Z PHAT Z
Nov 2, 2009 07:17 PM
cox
Sep 19, 2006 01:42 PM
Rob Hines
Jun 29, 2005 06:51 PM
robcassell
Mar 10, 2004 01:07 PM
