Gear 1,2,3 noise
Old Sep 25, 2002 | 05:13 PM
Zboy's Avatar
Zboy
Question Gear 1,2,3 noise
The mechanical sounds when shifting in gears 1, or 2 seem rather loud. But since this is my first manual car, I am not sure if it is supposed to be there? If i have my windows down and stereo off, I can definately hear all the sounds going on in transmission when shifting at low gears. Is this normal?
Old Sep 26, 2002 | 06:55 AM
WashUJon's Avatar
WashUJon
Can you describe the sound? I don't have a Z but every car I've owned has been a manual and some have just been louder than others during a shift. My current car is a 2000 Integra GS-R and it makes a very audible mechanical "click" as the shifter goes into gear. (NOT at engagement of the clutch) Other cars do this, so if you're really concerned you can call your service department or go to any other dealer and find a manual car. The "click" should be audible (from the outside) even if the engine is off and you're putting the shifter through the gears.
Old Sep 26, 2002 | 07:08 AM
John's Avatar
John
The gear whine is pretty loud, but it might be because of the aluminum gearbox case too (sound resonates differently through different materials)...
Old Sep 26, 2002 | 07:40 AM
Coz@CZP's Avatar
Coz@CZP
Concept Z Performance
Yes, it is lounder then usual.... Seems Nissan didn't insulate that area that as well as it should, sounds like a Z32 when it's missing it's upper boot.
Old Sep 26, 2002 | 07:53 AM
GodZilla's Avatar
GodZilla
Bad Mojo
How many miles do you have on your Z??
I knoticed a big difference in noise and vibration as the Mileage increased above break-in (It had less of both)
Old Sep 26, 2002 | 08:02 AM
z350z's Avatar
z350z
Charter Member #13
I haven't noticed this sound in mine at all. Maybe some are louder than others?
Old Sep 26, 2002 | 08:30 AM
integraowner's Avatar
integraowner
Default I have it
I have the sound AND I have an Integra GSR to compare to. The gear whine is louder than in the Integra, and the mechanical feel is also more pronounced in the Z.
I think the sound is best heard with the windows down in the Z. All my manual tranny cars have had some gear whine, but the Z is louder than those (with the exception of a really old *****'s jeep I once drove!).
I'm not sure if the sound has died down as I've put miles on the car (around 1300) or if it's just me getting used to the sound so I tune it out.
Barring any mechanical defects causing the sound, I think it's probably happening because there isn't much insulating the interior cabin from the tranny itself.
Old Sep 26, 2002 | 08:34 AM
WashUJon's Avatar
WashUJon
I'm not exactly sure what Zboy was talking about but he did mention "shifting". So, I don't think he means gear whine. I'm talking about the actual mechanical noise the shifter makes as it slides in and out of gear and that you can only really hear from outside the car. I'm not talking about any time the clutch is engaged at all. My GS-R's tranny whines a bit, but I thought Zboy was asking about shifting and not gear whine. Can Zboy clear this up a bit?
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
