Brake Pads
Old Apr 9, 2004 | 04:43 PM
EnthuZiast's Avatar
EnthuZiast
Guess whose back, back again...
Default Brake Pads
Nissan wants $275 for new front brakes.
Can anyone point me in the direction of a good company to buy new brakepads from.
I dont need anything extreme just want a nice pair of pads that I can install myself. I guess some more heat soak would be nice being that I dont have the Brembos.
Any suggestions would really help.
Thanks.
Old Apr 9, 2004 | 04:57 PM
ssk0771's Avatar
ssk0771
Get Hawk Pads from Pepboys or Tirerack. It will get rid of the dust & easy to install.
Old Apr 9, 2004 | 05:11 PM
SungNamZ's Avatar
SungNamZ
Default Re: Brake Pads
Thanks.
Hawk HPS @: www.raceshopper.com or 800-733-8380 they will cost you $56 + $9 s/h unless price has changed
Old Apr 9, 2004 | 05:15 PM
EnthuZiast's Avatar
EnthuZiast
Wow...thanks!
How long do those last?
Do you recommend having my old rotors machined or should I buy new ones?
What is the upside to different rotors?
Old Apr 9, 2004 | 05:46 PM
CaneZMD's Avatar
CaneZMD
Ah, the age old question, to turn, or not to turn rotors.
When I worked at Sears auto, we turned everyones rotors. But personally, unless they're warped, I don't like the idea of removing mass from the rotor. (Even if it's still inside of specs) And buying new ones for no reason doesn't make sense, so usually I just slap the pads on the old ones. (I no that technically that's probably not the best thing to do.)
Personally, I'm planning on getting some slotted rotors when I change my pads, mostly just for looks.
Old Apr 9, 2004 | 05:50 PM
EnthuZiast's Avatar
EnthuZiast
Thanks...but any clue how long these Hawk HPS pads should last me?
Old Apr 9, 2004 | 06:41 PM
MacGuru's Avatar
MacGuru
They'll probably last forever. They are REALLY HARD brake pads. I recently had them put on my Z (turned rotors) and I don't think they are as effective or good as the OEM. I feel the anti-lock kick in more often than the OEM pads. However, I will agree the brake dust is almost gone. IMO, I may go with a softer compound brake pad for better performance and live with the dust.
Old Apr 9, 2004 | 08:38 PM
D'oh's Avatar
D'oh
Was that $275 just for pads? If so, then it's just your dealer. All the dealers in my area are charging around $50 for the front pair or the rear pair (maybe slightly less for the rears).
Changing them yourself is very easy, so if the price was indeed for only the pads than you may be able to find them for less at a different dealer and make the change yourself.
-D'oh!
Old Apr 10, 2004 | 01:11 PM
FCallender's Avatar
FCallender
Axxis Ultimate is a good choice for the fronts. www.cobaltfriction.com
Old Apr 10, 2004 | 01:21 PM
EnthuZiast's Avatar
EnthuZiast
Someone else told me about the Axxis line.
And my dealer wanted $275.00 for machining front rotors and for new front pads.
Old Apr 10, 2004 | 01:27 PM
EnthuZiast's Avatar
EnthuZiast
Touring uses same size brakes as Enthusiast right?
Old Apr 10, 2004 | 05:57 PM
GaryM05's Avatar
GaryM05
Yes. All models but Track use the same size pads, front and rear.
Old Apr 10, 2004 | 05:58 PM
EnthuZiast's Avatar
EnthuZiast
thanks!
Old Apr 11, 2004 | 05:07 PM
MannishBoy's Avatar
MannishBoy
Wouldn't the ABS kicking in more frequently mean that the pads are grabbing harder, making the automated system have to keep the wheels from skidding where the weaker gripping pads would still allow for the tires to be rotating because they were grabbing a bit less?
Just curious.
Old Apr 11, 2004 | 06:02 PM
igor@af's Avatar
igor@af
I had the exact train of thought as you as I read through the ABS issue. If the ABS kicks in more often, the brake pads are grabbing BETTER than before.
Old Apr 11, 2004 | 11:38 PM
ssk0771's Avatar
ssk0771
Me too
samansharif
Sep 25, 2015 12:31 PM
