whistle sound wtf is it!?!?!
Old Jun 1, 2004 | 04:20 PM
JoshTreeFity's Avatar
JoshTreeFity
Originally posted by Yellow Stealth
For those describing the sound at freeway speeds and related to the acceleration, could the whistling sound also be described as a high pitched whine? That's what I get and I thought it was normal, but maybe not.
I just drove 600 miles over the weekend and had plenty of time to study this sound on my car. I came to the conclusion that it always happens when the accelerator is pressed at a certain percentage of its course. Does that make sense? In other words, the sound occurs when accelerating or decelerating, but always if the peddle is at a specific point.
So are some people never getting that sound? I attributed it to loud mechanics somewhere in the transmission hitting a certain resonance speed but maybe I should talk to the dealer.
Ya I was also thinking this. That is why i created this post I wanted to know if this was a malfunction or if this is a everyday occurance to everybodies Z.
Thanks for the inputs guys! Im really starting to love this forum! haha
Old Jun 2, 2004 | 06:38 AM
atadlo's Avatar
atadlo
i get a slight whistle that almost sounds like a weak blow off valve accelerating and most noticeably between shifts (letting off gas, clutch, then on the gas again). i am not 100% sure but i believe it is coming from the intake (im stock as well). given the fact the factory intake is somewhat of a cold-air induction i thought it may have been from that. i have checked around the filter housing looking for anything obvious open, loose or detached, but nothing so far. i havent really felt a negative impact on anything, so until the JWT is here im just keeping an eye on it. good luck!
Old Jun 2, 2004 | 05:16 PM
andycapp's Avatar
andycapp
Mine does the same thing that everyone is describing. I notice it at low speed as well. The observation that is sounds like a turbo is exactly how I would describe it. It sounds a little more quiet than my VW 1.8T used to sound under WOT, but its not too annoying or anything. I figured it had to do with the intake (mine is stock) and didn't think much about it, but I'll watch this thread in the event that its more serious....
Old Feb 1, 2005 | 09:20 AM
maxpowers's Avatar
maxpowers
My car is having the same transmission whine noise issues yours did. Do you know what your dealer did to fix it?
I have to mine in , but it only makes the noise when its extremely cold out, and its difficult to count on the weather being cold when I take it in.
Thanks,
Originally posted by absolutchi
if the sound gets louder as your revs get higher...it is most likely the whistling noise that some owners are getting in their transmissions. i bought my Z back in January and it tended to do it only when it was very cold but it would go away as the car warmed up and the fluids got looser.
i went to the dealer and had them deal with it. it should be covered under warranty. took a day to get it fixed and i had my car back the next day. hope that's what it is and it's not something bigger. good luck.
Old Feb 1, 2005 | 11:06 AM
AmateuRN's Avatar
AmateuRN
My tranny whines. It has since day one. Mainly when I'm in 1st, 2nd, or 3rd gear and let the car coast down to a stop. Around 10mph it sounds like a spaceship, when I apply the gas again it goes away...when I let off it whistles.
Old Feb 1, 2005 | 12:05 PM
jmaldonado's Avatar
jmaldonado
Mine started to whistle after installing the JWT Popcharger...
Old Feb 1, 2005 | 12:55 PM
Tekwon-V's Avatar
Tekwon-V
i have the same problem. it's highly annoying when you are driving on the interstate on a long trip.
whiny noise for sure. for the time being, i am just dealing with it by turning up the BLOSE system.
still have plenty miles/time left until warranty expires, so i will wait around and see what's up.
Old Feb 1, 2005 | 01:10 PM
Ivey's Avatar
Ivey
I think this thread is covering more than one kind of noise. I too have the tranny whine and it always occurs in 6th gear right around 3k rpms ~ 80mph. It is the same sound as described above - I only hear it when the gas pedal is pressed and goes away when the pedal is up even when it is still above 3k rpms (not a wind or speed noise). I haven't noticed it in any other gear.
I also have the other sound referred to above that is similar to a blow-off valve but that is coming from my CAI and is normal though I never heard it with my stock intake.
I'm taking it in to the dealer soon to put in another complaint about the tranny (shifts like a dump truck but no grind) and will see if they have ever heard of the whine noise.
If anyone get a solution to the whine noise please post.
Old Feb 1, 2005 | 04:21 PM
JonsilvZ's Avatar
JonsilvZ
Originally posted by Zedekiah
Could be factory wrapping.
Check the front diffuser right under the grill. My dealership forgot to remove it, so it was wistling around 130. Took it off and did another high speed test and it was gone.
I still have the factory wrapping. Had it since Nov 02 when I bought my Z! I never had whistling noises. Now I just hear the exhaust rumble.
Old Feb 1, 2005 | 04:42 PM
KIKILALA825's Avatar
KIKILALA825
Well i had this question up here few month ago. Seems during that time there wasn't lots ppl with dat problems yet.
The noise i got , i feel it's from my somthing behind the steering wheel. And i have also take my car to dealer's. The service manager there said he had that noise as well.
it's more like when u rev it, around 3k~4k rpm, you can hear a sound. but for sure not from the exhaust.
well mine is 03' and it's been no problem even tho the noise still comes up when my system is off..
Old Feb 1, 2005 | 09:31 PM
Risk's Avatar
Risk
Tranny whines
Diff whines
flywheel grinds
clutch chatters
mirror rattles
All this stuff used to bug the s#it out of me, but then another guy in my local crew said that he used to feel the same way about all of that, and now just deals with it. I have learned to do that too.
Old Feb 1, 2005 | 09:55 PM
zmespeed's Avatar
zmespeed
Default Re: whistle sound wtf is it!?!?!
Originally posted by JoshTreeFity
When I drive my car at higher speeds even sometimes at low speeds i get this really annoying loud whistle noise. My car is completely stock do you guys have any idea what it is?
Any info is greatly appreciated!
Thanks,
Josh
it is an airrow dynamics issue. i think it is caused by air streaming by the little windows. the hatch over hangs a bit there. at low speeds a head wind might be to blame. but it is most definatly an airrow dynamics issue. other possiblities are the mirrors maybe try dirving fast with them in and see it the sound goes away. or you could use some mascing tape and try smoothing out the line at the end of the little window. i have this problem too but i have never realy gone to these exstents to solve it.
Old Feb 2, 2005 | 05:06 AM
maxpowers's Avatar
maxpowers
Yes I think this thread is covering many differnt whine noises. It seems there is mine (i) a whine in the tranny, proportionate to RPM only when cold, (ii) whine at higher speeds in 6th, and (iii) whine from wind noise.
I'd be more concerned if I was out of warranty but its annoying.
Old Sep 29, 2019 | 02:38 PM
Z33_818's Avatar
Z33_818
Default I know this thread is old but I know what it is.
Do u have Bluetooth hooked up? I had mine hooked up and my phone is picking up the rpm. It sounds like spool. But if I turn my stereo off it stops. Goes up with my rpms.
Old Sep 30, 2019 | 04:22 PM
liven Z life's Avatar
liven Z life
Haha it was 2005 so prolly not
Obadabot
Jun 18, 2023 11:31 PM
sales@czp
Sep 23, 2019 03:30 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
samansharif
Sep 25, 2015 12:31 PM
