Scraping sound when moving from parked
Old Sep 10, 2004 | 12:27 PM
Setter32's Avatar
Setter32
Default Scraping sound when moving from parked
I'm noticing this slight short scraping or grinding sound when my Z starts rolling after being parked for a while. Actually, I can feel it through my feet more than I can hear it. It only happens if I have parked the Z for a bit, and only when I initially start rolling.....then it's gone. Anyone have any idea what this is, and is it normal for the Z?
Old Sep 10, 2004 | 12:39 PM
KrazY-2K's Avatar
KrazY-2K
I get that same noise once in a while also. I would also like to know what this is
Old Sep 10, 2004 | 12:41 PM
m'sZ's Avatar
m'sZ
When I had my Z, I had it as well. Never did find out what it was from.
Old Sep 10, 2004 | 01:44 PM
zand02max's Avatar
zand02max
I have the answer.
Next time, do not park so close to the curb,. That sound you hear is your front end scraping the curb.
Hell, I have no idea!
Old Sep 10, 2004 | 01:56 PM
KrazY-2K's Avatar
KrazY-2K
Originally posted by zand02max
I have the answer.
ROFL... I love that avatar. That thread is just hillarious.
Back on topic, I'll be on a completely flat surface with no objects around and it does that. I don't think it's harmful, though.
Old Sep 10, 2004 | 02:11 PM
Setter32's Avatar
Setter32
I'm taking my Z in for a new pair of front tyres, in a few weeks. I'm thinking of asking them to check out this grinding noise, but I don't want them to mess up my Z in the process.......so maybe I should just keep my mouth shut. She's been running perfect except for the very slight feathering at 8.5K (I'm surprised they're willing to give me new tyres ) and this subtle grinding noise, which is not even an issue if it's suppose to do that. Hence, that's what I'm trying to find out.
Old Sep 10, 2004 | 02:17 PM
shinz's Avatar
shinz
does it sound like you're stepping on an empty coke can? I had that on my audi, it was the ABS.
Old Sep 10, 2004 | 03:16 PM
Setter32's Avatar
Setter32
Not quite...........maybe............not sure.........
It does sound like maybe something is being released. Not sure.
Old Sep 10, 2004 | 04:01 PM
AZZGUY's Avatar
AZZGUY
I got that noise when my brakes needed replacing - of course by that time the drums had to be turned! Ouch !! ( this was on the Maxima - not the 350 Z ) Does this sound comforting??
Old Sep 13, 2004 | 11:56 AM
Setter32's Avatar
Setter32
Yes!......cuz the Z doesn't have drums.
Old Sep 13, 2004 | 08:45 PM
AZZGUY's Avatar
AZZGUY
They have discs that can be harmed! That's why one doesnt want to buy brake pads the metal implanted! Might give you the same bad sound --
Old Sep 13, 2004 | 09:19 PM
longbowe's Avatar
longbowe
Is this the one where it sounds like a slight scraping of metal on metal when you go slowly past 1800 rpm? I have no idea what it is either, but I've had that since the beginning.
Old Sep 13, 2004 | 09:35 PM
Everdark's Avatar
Everdark
I wondered that myself, then I checked the manual on page 5-21 explains it all. The car has a self-testing Ant-Lock Braking System diagnostic feature each time you start up the car. You'll hear a clunk noise and maybe pulsation of the brake pedal. It's all normal and it's all good
Old Sep 14, 2004 | 05:30 AM
AZZGUY's Avatar
AZZGUY
7000+ miles - havent heard that one yet.
Old Sep 14, 2004 | 08:06 AM
bstansbu's Avatar
bstansbu
Default Thanks
Good heads up. I live on a fairly steep road, so every time I back my Z out of the drive way then proceed to go down hill to the stop sign I hear and feel the ABS kick on for only 1 second then gone. I feel better now. Thanks for the info. BEN
Old Sep 14, 2004 | 09:03 AM
OP Z's Avatar
OP Z
Actually, I believe it is the brake pads against the disc. The pads are compressed against the disc with the parking brake set and "break loose" after the brake is released and the car starts to roll.
Old Sep 14, 2004 | 09:32 AM
ChinaClipper's Avatar
ChinaClipper
Well, not quite. The original poster of this thread needs a parking brake adjustment. Many others with that minor scraping sound when first rolling need it too. The parking brake IS actually some small shoes operating on the internal drum which is the hub of the rear brake rotors.
Obadabot
Jun 18, 2023 11:31 PM
350Z_Al
Oct 29, 2020 07:44 PM
samansharif
Sep 25, 2015 12:31 PM
