Is this Normal?
Old Oct 5, 2004 | 12:30 PM
myehrick09's Avatar
myehrick09
Default Is this Normal?
Can your Z shift to neutral from 1st gear w/o stepping on the clutch? Mine does, I just noticed it this afternoon on my way to lunch. Is there something wrong with my car or is it just one of the feature of it that I just discovered? Info on this peeps......
Old Oct 5, 2004 | 12:33 PM
tacomaboy's Avatar
tacomaboy
If you match RPMs you can shift to neutral from any gear with a small push...
very normal.
Old Oct 5, 2004 | 12:38 PM
Ivey's Avatar
Ivey
It's called clutchless shifting and it is possible to move out of, and into any gear if the revs are matched correctly. When reaching peak speed for a gear, right when you let off the gas you can slip out of the current gear and wait for the revs to drop to where the next gear takes over and then slip into that gear. All can be done without any grinding noise - if it grinds you are not doing it 100% correctly.
try a search for clutchless shifting, there are some detailed threads on this subject.
Old Oct 5, 2004 | 12:43 PM
myehrick09's Avatar
myehrick09
Bro, I'm not even stepping on the clutch at all. My car can shift from 1st to neutral. Makes we wonder why it does that?
Old Oct 5, 2004 | 12:48 PM
tacomaboy's Avatar
tacomaboy
right... when the transmission spins at the right speed, you can move it out of gear without touching the clutch.
perfectly normal.
Old Oct 5, 2004 | 12:52 PM
Ivey's Avatar
Ivey
clutch"less" shifting. no need to touch the clutch at all and you can shift into neutral and then into any other gear. there is actually some good simple info at: http://www.howstuffworks.com/ on how the clutch and tranny works.
worth a read if bored.
there is no real advantage in doing so unless you have a lightweight flywheel and can drop rev faster than if you had used the clutch. you can however damage the syncros etc.
Old Oct 5, 2004 | 12:57 PM
myehrick09's Avatar
myehrick09
I got worried there for a sec....thanks bro's for the info
Old Oct 5, 2004 | 11:18 PM
shinzter's Avatar
shinzter
thats interesting. but i still dont get it if you are in a full stop sign and it just goes in 1st from neutral. does everyone's z do that?
if not, what makes his car so different?
Old Oct 6, 2004 | 07:25 AM
Ivey's Avatar
Ivey
You shouldn't be able to push from neutral to 1st while at a full stop without using the clutch... if so, you're Z is unique (a.k.a. broken)
shifting without the clutch is done between gears while moving.
myehrick09, correct me if I am wrong but you aren't shifting from neutral to 1st without the clutch while stopped right?
Old Oct 7, 2004 | 10:30 AM
Hazade's Avatar
Hazade
no... going from neutral to first from a complete stop wont work.. you can shift from 1st to 2nd etc. without the clutch rather easily
Old Oct 8, 2004 | 01:32 PM
myehrick09's Avatar
myehrick09
Yes you are right, you can't but from 1st to neutral you can. As long as your speed is less than 5mph you should be able to shift easily w/o depressing the clutch according to Nissan's Service dept!
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sales@czp
Sep 23, 2019 03:30 PM
codek
Sep 28, 2015 03:03 AM
