Gran Turismo 3 Challenge
Old Jun 15, 2002 | 04:43 PM
blackknight's Avatar
blackknight
Ya know, I've owned that game for over a year now I think. How the hell or where the hell do you win it since you can't buy it?
Old Jun 15, 2002 | 07:43 PM
RADZ's Avatar
RADZ
Charter Member #39
Default Conditions?
Can we upgrade the Z in the game? I got a 1:20 but my Z was modified. If it does not matter let me know and I will send confirmation.
Old Jun 15, 2002 | 09:00 PM
Dave's Avatar
Dave
You must be able to do better than a 1:39, I haven't played in months and I just popped in the game pulled consistent 1:37s with a best of :
1:36.746 after just my 4th lap.. I am sure this can be brought down to as fast as the 1:34s... I'm working on getting this recorded and put online.
Old Jun 16, 2002 | 01:14 AM
droideka's Avatar
droideka
Cool
I hope a pic might suffice. I don't have video capability and I'm on dial-up anyway. I do have the replay saved for verification purposes.
1:35.925 in the 7th lap.
Old Jun 16, 2002 | 03:39 AM
350zhawaii's Avatar
350zhawaii
how do you get the z on GT3 I've been trying but i don't know how to get ie what race do you have to do to get it.
Old Jun 16, 2002 | 03:46 AM
raceboy's Avatar
raceboy
LOL, I don't know where that 1:39 time came from. My lap in an unmodified Z was a 1:33.118 in that video. The entire video is only 1:35!! I actually was in a GT3 Tournament when the game first debuted. My brother and I still play for hours at a time on my 55" Mitsubishi. I took about 5 laps to do this and I have no dobt I could get into the 32's.
Old Jun 16, 2002 | 08:04 AM
raceboy's Avatar
raceboy
<a href="http://secure.photoloft.com/shoppl/storefront.asp?s=cano&pid=default.asp&dept_id=444&u=1711790& a=1261050&i=9630022"><img src=http://hyperphoto.photoloft.com/view/exportImage.asp?s=cano&i=9630022&w=640&h=480></a>
Here is a better time I just set (1:33.057). I am pretty sure I could get into the 1:31's as I was ahead of my ghost image a few times but couldn't get it perfect. Happy hunting!!
Old Jun 16, 2002 | 09:05 AM
droideka's Avatar
droideka
That's more like it! Someone who calls themself raceboy AND has driven on LSIR in real life better run faster lap times than me! Where are you taking off all of that time? In the Andretti hairpin, the corkscrew, or elsewhere?
Old Jun 16, 2002 | 09:52 AM
raceboy's Avatar
raceboy
Here are the sector times from the analyzer function with a full lap analysis by yours truly at the end:
Sector 1: Speed 95mph (This is speed on entry to the section)
Time 6.693
AVG 104mph
2: 114mph
7.472
67mph
3: 66mph
3.691
75mph
4: 80mph
4.043
77mph
5: 80mph
2.786
85mph
6: 90mph
4.165
92mph
7: 94mph
5.828
104mph
8: 111mph
5.987
81mph
9: 79mph
5.026
84mph
10: 89mph
4.822
93mph
11: 97mph
5.804
100mph
12: 103mph
6.695
78mph
13: 71mph
7.214
85mph
14: 90mph
3.651
96mph
15: 96mph
3.947
81mph
16: 79mph
3.275
82mph
17: 62mph
4.050
50.mph
18: 57mph
7.893
80mph
P.S. You have to use manual shift, IT IS FASTER!! And you need to learn to drive using both analog sticks unless you have a wheel. Left one for steering right one for gas(forward) and brakes (back)There, hope that helps. The only way to truly run fast is with infinite steering, gas, and brake control. I would say I have done 2000 laps on this track in GT3. The key is momentum.
The lap starts at the hairpin leading on to the front straight. Take it in 2nd gear coming in real wide and just clipping the true apex. You need to hit the start finish line going at least 95mph. Come wide over the crest of turn one and set up for the Andretti hairpin, braking here is critical for a good lap speed. Take turn 2 in second gear and don't shift up to 3rd before turn 4 (turn 3 doesn't really count as a turn at all). Make sure you come in wide again with a correct apex. Barely lift through three using throttle to steer car. Shift to third for turn 5 going through the turn full throttle and jumping the curb then drifting all the way to the outside. Stay in 3rd gear at and set up wide for 6. 6 is a late apex turn and extremely importand because it's full throttle from here all the way to the corkscrew. Brake in a straight line. Turn in and shift down to 2nd (I don't care that they tell you to take the turn om 3rd gear) and power out the turn and on up the hill. 7 is pretty easy. A full speed 3rd gear corner, no lifting!! Going up the hill to the corkscrew you should be on the Left side of the tract to make sure you don't hit the outside curb while braking for the Corkscrew. Crest the top of the hill for the CS on the right side. Brake heavily once you have crested the hill and not before. Shift down to 2nd gear and turn in. You should be going pretty slowly and run over the leftside curbing. once you get the car pointed straight down the hill full throttle to set up for Rainey Curve. Rainey curve (turn 9) is almost and early apex left hander taken almost flat in third gear using the trottle to modulate weight on the front tires. You should only lift ever so slightly for this turn. Sweep back across the track setting up for 10. 10 is also an early apex corner, bush the brakes before turning in while in 3rd gear. Shift down to second and redline all the way through the corner, then back to 3rd gear. Now the turn 11 hairpin. Pretty easy to blow a good lap right here. Brake early, apex late taking the corner in second gear making sure to not over or understeer into the dirt on exit. There you have it.
Old Jun 17, 2002 | 07:10 AM
raceboy's Avatar
raceboy
Anyone beat 1:33.057 yet?
Old Jun 17, 2002 | 07:47 AM
Dave's Avatar
Dave
I am just into the 1:34s (1:34.930), its that last turn before the straight that screws me up.. and the turn before you get on the throttle all the way to the corkscrew..
Also, how come droidekaus and I have the Nissan Z concept at 273hp and you have it 269?
Old Jun 17, 2002 | 07:54 AM
raceboy's Avatar
raceboy
GT is weird. They try to do like a fake gentleman's agreement type thing. The screen I am using here is the replay theater screen. You guys are showing the screen in the actual free run mode. The Z has an "official" 269 hp in the game shown on my screen, but in reality it's 273 in the game if that makes any sense at all. Also, as cars get broken in they gain a few ponis in GT3 as well.
Old Jun 21, 2002 | 01:47 AM
RADZ's Avatar
RADZ
Charter Member #39
Cool beat this raceboy
Here you go. Happy hunting.
Old Jun 30, 2002 | 07:36 AM
raceboy's Avatar
raceboy
RADZ, nice try, but you have to use the Arcade Mode car and not one imported from the simulation mode! To get the car available in the arcade mode you have to pass every level. Just using the SIm Mode car, full suspension, better gearing, lighter weight, race tires-basically every mod but HP increases I can turn 1:21's.
Old Jun 30, 2002 | 06:45 PM
RADZ's Avatar
RADZ
Charter Member #39
Default Post it and I will beat it.
Simple as that.
Workshop12
Mar 23, 2020 01:45 PM
sccarally
Meet-Ups / Events (Texas)
Sep 27, 2015 01:06 PM
