350Z filter is TINY!!! A comparison. . .
Old Nov 20, 2004 | 03:04 PM
DBZ's Avatar
DBZ
Exclamation 350Z filter is TINY!!! A comparison. . .
I know this has been discussed quite a bit on the forum, however, Wow! Who knew the Nissan filters were so small. I am going to have to reconsider my oil change intervals. I was originally going to do it every 5000 miles, however after looking at the oil filter, it might be wise to go down to every 3000 miles. Here is a comparison of different oil filters.
The black one in the left side is the OEM oil filter for my '01 IS300. The white one in the middle is the longer "Maxima" filter and the one on the edge is the OEM Honda filter for my '04 VTX 1300 S V-Twin cruiser. The diameter of the Nissan filter is the same as the Honda motorcycle filter. The actual OEM 350Z filter's length is somewhere between the longer Maxima and the shorter Honda one.
[IMG][/IMG]
Old Nov 20, 2004 | 03:06 PM
DBZ's Avatar
DBZ
Default Here's another shot. . .
[IMG][/IMG]
Old Nov 20, 2004 | 03:07 PM
DBZ's Avatar
DBZ
Default And another one. . .
[IMG][/IMG]
Old Nov 20, 2004 | 03:42 PM
Conceyted's Avatar
Conceyted
now put the mobil one filter for the 350z next to those and you will have a new fat boy winner
Old Nov 20, 2004 | 04:05 PM
jeffie7's Avatar
jeffie7
The CBR F4i and 600RR filter is smaller then the older CRB F1/2/3/4s filter.
They say the older bigger filter "same DIA just a good bit longer" fits but could hurt your engine since it's not able to hold up to the higher pressure......
not sure what the real reason is all I know is yes the 350Z filter is smaller then most any other filter about the size of a bike filter but I'm hoping nissan knows what they're doing.
I guess thats just more reason to change the filter every oil change
Old Nov 20, 2004 | 04:10 PM
n8vz's Avatar
n8vz
you can use the Maxima -9E000 filter on the Z.
Old Nov 20, 2004 | 04:20 PM
Ronny's Avatar
Ronny
Bigger isn't better!
Old Nov 20, 2004 | 04:26 PM
azrael's Avatar
azrael
Mobil 1 makes a variety of much larger filters that fit the VQ.
Old Nov 20, 2004 | 04:39 PM
uro279's Avatar
uro279
what's the benefit of a larger filter?
Doesn't the OEM filter have some kind of 'valve' that protects in some manner (I read it along time ago on this forum), whereas the aftermarket ones don't?
Old Nov 20, 2004 | 05:56 PM
jun14scr's Avatar
jun14scr
use the 9800. it has better overall construction and filtration elements, not to mention it's a little bigger.
Old Nov 20, 2004 | 06:20 PM
stumpmj's Avatar
stumpmj
Mobil-1 filters have the anti-drainback valve too. They're alos better constructed than the OEM ones which use cardboard to keep the internal parts toghether.
The advantage of a bigger filter is that it can filter more particles without restricting the flow of oil. Basically, you go longer between changes. In this case though, the bigger filter also happens to be better constructed and filter better (I used to have a link to an online article comparing filters but I lost it in the great computer crash of last week.).
Old Nov 21, 2004 | 03:18 PM
350Zteve's Avatar
350Zteve
Can someone post the specific Mobil 1 model numbers to get?
Old Nov 21, 2004 | 04:48 PM
HokieZ's Avatar
HokieZ
I use the M1-105. It's a much larger filter and better constructed as mentioned above. I'll snap some pictures. I have a bunch of extras from a large buy I did so I can send 4 for $30 shipped to whomever wants them.
Old Nov 21, 2004 | 11:47 PM
love1u0's Avatar
love1u0
Default Re: And another one. . .
You think that is small, well my Nissan Titan oil filter is as big or smaller than the filter on the right. And it takes 7qts of oil.
Originally posted by DBZ
[IMG][/IMG]
Old Nov 22, 2004 | 12:32 PM
Nominee's Avatar
Nominee
I'm using the Maxima filter. It's slightly longer in length.
etkms
Jun 19, 2022 06:30 PM
JjL
East Canada
Jun 12, 2019 03:04 AM
hulkout
Apr 28, 2017 09:00 PM
Justin100
Nov 29, 2015 03:58 PM
