2009+ 370Z General discussion and news for the Z34 (2009+) Nissan 370z with the new 3.7-liter V6
MotorAuthority--Nissan 370Z gets 332hp, rev-matched manual transmission 11.11.08
Old Nov 11, 2008 | 12:19 PM
  #101
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Originally Posted by Motormouth
yeah, even tuned to lower power levels, so if you wish to unlock it. but it seems some of the turbo cars suffer from temp control problems.
I have always been MORE than happy with the N/A power levels of my 03. I guess I just don't get the need for speed I can't use really or the issues associated with it. I guess my dick is big enough (just keeding with you speed junkies)
Old Nov 11, 2008 | 12:23 PM
  #102
Motormouth's Avatar
Motormouth
Originally Posted by mhoward1
Remember that a manual rev match doesn't begin until the gear is selected and clutch release has begun. So all they would need is to know what gear is selected and speed, both of which are already recorded in the data box. So the software would then match RPM of current speed and gear selected on clutch release, which should only take about 1/10 of a second.
The could even take a short cut and match RPM once the gear is selected and speed is known, but that would mean higher RPM's on in clutch coasting unless the car was in neutral.
yeah, that is true. going through the process in my head, I guess it would be very simple for a program to do this.
Old Nov 11, 2008 | 12:24 PM
  #103
Mansmind's Avatar
Mansmind
remember, the Miata is a true sports car. sports cars aren't about massive power always. it's about the chassis and capability of the car. the Z with 289hp was more than enough car for many people it's just that the mega cars from like Audi and **** with 500hp totally skew people's perceptions these days. if the car is fun to drive and is not underpowered, it's still a sports car!
I just can't imagine how exactly a manual rev matching would 'work'. guessing it'll be a trigger once the lever slots into the lower gear, cause otherwise it'll be guessing when you clutch in. will it be quick enough for a fast shift? I don't know. seems clunky but what do I know. need videos
and though it is smaller I saw nothing about it being stiffer.
I agree with everything you said, and frankly the Miata is a blast to drive although the car itself is just too cramped for my taste. You can certainly throw one around however.
The truth is that the current power is "enough" for anyone, me included...but that doesn't stop us from wanting more does it? Most of us like to mod to varying extents..partly from the enjoyment of doing it but also because we like the little performance edge it gives. Does it mean you roll down the street screaming "I've got more than you?". Of course not.. but each of us feels it each time we squeeze the pedal.
332 won't keep me from buying the car. Why would it 306 didn't? If I truly wanted more power and that was the bottom line.. I wouldn't be driving a Z to begin with. Still.. I would have thought they would up the ante a bit more than they did when moving to the 3.7.
Old Nov 11, 2008 | 12:30 PM
  #104
350Zenophile's Avatar
350Zenophile
Anyone else think the rev-matching manual is going to save Nissan hundreds of thousands in replacement trannies? I'm sure they'll still be people capable of breaking it, but I'm also sure 99% of the premature synchro wear out there is from people not rev-matching.
Old Nov 11, 2008 | 12:36 PM
  #105
BaTMan_4's Avatar
BaTMan_4
Mostly likely it means than when you do a down shift (3-2) the engine will increase the idle speed to match the input shaft speed. This will increase the smoothness of the clutch release.
Think about when you come to a light and shift down to 2nd at 40+ mph. With out a rev match the car lurches forward and engine braking occurs. With rev matching the relase is smooth and no lurch.
this is gonna take some time getting used to, im so used to blipping the throttle for a smoother downshift....now with this new innovation it i take it that it would sounds like im over reavving
Old Nov 11, 2008 | 01:41 PM
  #106
Sensi09's Avatar
Sensi09
Works Concepts
This computerized rev-matching has some potential, but I'd expect the system to become confused during very spirited driving. Even if it doesn't rev-match until you select a gear, I'd expect uneven rev-matching if the clutch is released very fast.
And since the threads have been merged, I'll comment on HP too. Regardless of old or new HP ratings, the 370Z will be quite a bit faster than the e46 M3. As it stands now, the HR Zs are already as fast the as the e46 M3. The e92/e90 M3 is another story though as that car will be a good amount faster than the 370Z for years to come.
Old Nov 11, 2008 | 01:46 PM
  #107
350Zforlife's Avatar
350Zforlife
370Zforlife
Very interesting. It'll be weird in to get used to in the beginning.
Old Nov 11, 2008 | 01:56 PM
  #108
Sensi09's Avatar
Sensi09
Works Concepts
If you think about it, many times rev-matching occurs at the same time you're actually shifting. So if I downshift from 5th to 3rd, I'd have the necessary revs even before I shifted into third.
I really don't see how the rev-matching system will accommodate this and anticipate which gear you're going into.
Old Nov 11, 2008 | 02:13 PM
  #109
mhoward1's Avatar
mhoward1
With modern beveled syncros, the between gear shiftings before clutch release really doesn't gain much at all. It saves a little wear on the syncro itself, but its minimal.
If someone is doing it for smoother shifts, then the rev blip is too early to improve smoothness on the chassis.
Old Nov 11, 2008 | 02:30 PM
  #110
failsafe306's Avatar
failsafe306
rev matched, hmm. seems like one more thing to possibly break/cause warranty issues later on.
Old Nov 11, 2008 | 02:32 PM
  #111
marques1's Avatar
marques1
I'll keep my o3 350z. The 370z won't let you go over 110 miles per hour unless you are on a track, lol just joking.
Old Nov 11, 2008 | 02:42 PM
  #112
SnakeBitten's Avatar
SnakeBitten
I hope this is not just a gimmick...Do we really need it NO but if its implemented in a reliable way, doesnt get confused during spirited driving and doesnt have penalities if its used then Im for it... Im partial to doing it myself...I do it so often now that I dont know what ill do with myself in between stoplights.
Old Nov 11, 2008 | 02:48 PM
  #113
Ataru074's Avatar
Ataru074
I agree that the E46 M3 was fast or close to an HR 350z (I still think that on a track the Z is a bit faster... for what I have seen)
The e92 isn't so faster... it's still a fat goat that suffer of an incredible understeer, especially after few laps on a track.
It's sharp, for the first few laps.. it's really sharp.. and looks neutral to oversteering for its 420hp... but the balance is quite understeering at the limit when the front tires start overheating.
we will see... we will see.... a cayman S can catch an E92 M3 on a track and sometimes be even faster (slow technical track) if the 370z is going to match or overtake the actual cayman... that's it. is going to be faster than a E92 anywhere but straight line and really fast tracks.
Old Nov 11, 2008 | 03:00 PM
  #114
PA 19103's Avatar
PA 19103
This is like a nightmare coming true = manual rev matching.
If VDC, Traction Control, etc in many cars have buttons to turn them off, I just hope 370Z has a button to turn its rev matching off or like an option/package which I will be avoiding because I really enjoy the spiritual driving.
Old Nov 11, 2008 | 03:47 PM
  #115
mcarther101's Avatar
mcarther101
Rev matching tranny? Just another system to eliminate the driver IMO. So no need to heel-toe brake anymore with the Z eh?
Old Nov 11, 2008 | 04:33 PM
  #116
trebien's Avatar
trebien
Not necessarily. The M3 doesn't have much aftermarket headroom for the already strung out engine, but the 370Z should easily be able to tap out another 30HP with simple bolt-ons and a tune, if the G37 aftermarket is any indication.
I hate comparing stock cars versus modded cars, but I have to since there is very little to mod the M3... the mods are much less attainable for it. The M3 is making high 12s in the quarter, and I think the Z will be commonly capable of that with exhaust/cats/tune/intake... simple bolt-ons that many people would consider. I'm not talking about cracking the engine for high compression pistons, or cams, etc. I'm talking about $2000 worth of simple add-ons that are highly attainable and easily installed.
A modded 360HP Z has a very similar power-to-weight ratio as an M3. And the 400+ pound lighter Z will pay dividends on a track.
3200 pound Z with 360HP = 8.89 lbs/hp
3700 pound M3 with 414HP = 8.94 lbs/hp
8.89 > 8.94
Once again, it's all about the weight savings.
Old Nov 11, 2008 | 05:06 PM
  #117
mhoward1's Avatar
mhoward1
Still needed, especially with trail braking.
Old Nov 11, 2008 | 07:05 PM
  #118
DiscoZ's Avatar
DiscoZ
Hrmm... so close to the Z4M. Z4M weighs close to 3,000lbs dry and makes 290whp on average, stock.
Old Nov 11, 2008 | 07:20 PM
  #119
OldDirty Z33's Avatar
OldDirty Z33
Love how everyone thought it was going to be some beast, 500hp and 100000TQ at 2000lbs.
Old Nov 11, 2008 | 07:26 PM
  #120
mthreat's Avatar
mthreat
8.89 > 8.94
Did you just say 8.89 > 8.94?
I guess you're defining the > symbol as "is better than"
