MotorAuthority--Nissan 370Z gets 332hp, rev-matched manual transmission 11.11.08
People love rev-matching when they do spirited driving or track their car.
This feature is more of a conveniance factor than anything else. I don't see why people would want this feature if they are tracking their car.
Like someone said, I hope it has an on/off switch. Part of the joy of a true manual is rev-matching.
I agree that the E46 M3 was fast or close to an HR 350z (I still think that on a track the Z is a bit faster... for what I have seen)
The e92 isn't so faster... it's still a fat goat that suffer of an incredible understeer, especially after few laps on a track.
It's sharp, for the first few laps.. it's really sharp.. and looks neutral to oversteering for its 420hp... but the balance is quite understeering at the limit when the front tires start overheating.
we will see... we will see.... a cayman S can catch an E92 M3 on a track and sometimes be even faster (slow technical track) if the 370z is going to match or overtake the actual cayman... that's it. is going to be faster than a E92 anywhere but straight line and really fast tracks.
Not necessarily. The M3 doesn't have much aftermarket headroom for the already strung out engine, but the 370Z should easily be able to tap out another 30HP with simple bolt-ons and a tune, if the G37 aftermarket is any indication.
I hate comparing stock cars versus modded cars, but I have to since there is very little to mod the M3... the mods are much less attainable for it. The M3 is making high 12s in the quarter, and I think the Z will be commonly capable of that with exhaust/cats/tune/intake... simple bolt-ons that many people would consider. I'm not talking about cracking the engine for high compression pistons, or cams, etc. I'm talking about $2000 worth of simple add-ons that are highly attainable and easily installed.
A modded 360HP Z has a very similar power-to-weight ratio as an M3. And the 400+ pound lighter Z will pay dividends on a track.
3200 pound Z with 360HP = 8.89 lbs/hp
3700 pound M3 with 414HP = 8.94 lbs/hp
8.89 > 8.94
Once again, it's all about the weight savings.
8.89 > 8.94
I'm not familiar with the mods available for the e92 M3, but I do know that the same bolt-ons that are available for the Z will be available for the M3. I haven't read up or am familiar with the new M3, but as with past M3 and with past Ms, the popular bolt-ons will be exhaust, intakes, software, gearing and maybe those darn RPI scoops. Headers if they're not out yet, should be available soon.
The cost might be greater, but the type of mods are all the same.
With modern beveled syncros, the between gear shiftings before clutch release really doesn't gain much at all. It saves a little wear on the syncro itself, but its minimal.
If someone is doing it for smoother shifts, then the rev blip is too early to improve smoothness on the chassis.
With F1 style transmissions, the computer controlled clutch makes all the difference. When one taps the paddle a few times, the computer knows which gear is selected and how much to rev-match. On the 370Z, with a traditional manual and clutch, I don't see how this will happen appropriately.
Regardless of smoother shifts or wear, one starts to rev-match simultaneously as they're shifting gears. Just don't see how the computer will begin to rev-match without knowing which gear you wish to select.
A Rev done in between gears doesn't gain anything in the way of performance. Only a rev match done as the clutch is being released increases smoothness and chassis dynamics. At this point the CPU knows which gear has been selected and the current speed of the car. This is the appropriate time to rev match for performance driving.
the only weakness I have seen is reliability on the track of the stock vettes.. on the other hand, incredibly fast for the money.
yes and no... the M3 is altready a highly developed almost "money no object" sedan.. at least in the engine compartment. 4 liter, 415 hp, 8200 rpm... you don't squeeze too much more from this kind of engine.
just take a look of an M3 header... isn't the POS cast manifold we were used to see on a Z... and again the exhaust line... also the aftermarkets pretty much carbon copy the design of the stock one... and that means only one thing... they cannot improve easily.
same story for the Z4M...
on the Z is clearly know that also on a full N/A car the money required to get a 10/15% HP/tq more is resonable.
the biggets advantage of a 350z (or 370z, guess is going to be the same) is the more sofisticated front suspension with the double wishbone instead of regular mcpherson.
probably you won't feel it on the road.. but where it counts makes up for the HP difference.
Z4M with intake scoops, ESS tune and exhaust has put out 317/318whp (two different cars). Videos on Youtube/Zpost. Stock is approx 290whp. Looks like the 370Z will be fairly close.
Yes. An astute observation. I agree.
for everyday driving the revmatching will be great.....as soon as i get to a corner it gets turned off....
u have to remember that enthusiasts are not the only market...and also not all enthusiasts are hardcore enthusiasts......auto revmatching sounds like heaven for 80% of prospective buyers, and they would never think of disabling it...
i just cant wait for them to hit the streets...and we see what they really do.....
when is the release date for these...still unknown???
Regardless of smoothness and or speed, it just makes for a much more fluid movement/shift IMO.
Do you downshift into gear, then begin to rev-match? I tried to think about it when I was driving yesterday, and for myself, the rev-match and shifting into gear happens simultaneously.
While rev matching as you go into gear helps the syncros a bit (but not much), by the time the clutch release is done the rev's have dropped back down and the input shaft now spinning slower than the transmission, so any smoothness is lost. By Doing the rev match as the clutch is released, or just before the pedal is lifted, the input shaft is then brought to the correct speed and then engaged.
Sort of like a double clutch downshift, you're on the gas giving revs prior to actually getting into gear.
MyZ2Slow
Mid-Atlantic Marketplace
Sep 9, 2015 10:17 PM
