Left foot brakingg hell?
Why did Nissan wire the car so accelerator cuts when you have foot on the brake? Is there a known hack to disable this electronic nanny device? Makes it hard to left foot brake on the track!
Most likely engineered in to avoid liability issues. In a society that blames companies for unintended acceleration, legal departments have a lot of influence into things like this. But I road race my 350Z in SCCA and haven't noticed much problem with it- but then again, I'm primarily a right foot braker...
I assume this is similar for the 370Z.
Don't you watch the Nissan advertisements? Here's one that specifically mentions the fact that their cars have had brake override for six years.
http://www.youtube.com/watch?v=CWTnEGGad78
Since there's no mechanical linkage to the accelerator pedal, move the pedal assembly to the brake pedal. You'll be able to modulate the accelerator pedal angle with your foot at the same time you're applying pressure to the brake with your leg.
It'll be similar to using the combination rudder/brake pedals in a light plane, except you'll only be doing it with your right foot.
Ideally, an extra accelerator pedal would be mounted on the right side of the brake pedal and slightly lower. That way, you could move your foot to the left to step directly on the brake pedal for hard braking, and use the extra pedal for heel-and-toe work. The regular accelerator pedal would be used for normal driving. You could rig the electronics so whichever one was not at idle position would be sending the signal to the ECU.
CFAUVEL
Oct 1, 2015 03:20 PM
