2009+ 370Z General discussion and news for the Z34 (2009+) Nissan 370z with the new 3.7-liter V6
I知 Having Issues With My 350z
Old Aug 4, 2019 | 12:36 PM
Xenii's Avatar
Xenii
Default I知 Having Issues With My 350z
So I知 somewhat of a new owner of a 350z and I知 not one who knows a lot about cars but I知 trying to learn! So lately my Z has been completely shutting off as I知 driving the service engine , slip and tcs light will go off and then it値l just shut off. I致e checked to see what it was and I got the P0345 which is the camshaft sensors and I changed that and it was good for a day and then it did the same exact thing. So once again I checked and then it said it was the crankshaft sensor so I changed it and it still doing the same thing and then my rpm goes all hay wire on its own and I知 just confused as to what痴 going on , if you guys have had this issue before and help give me an idea to what it could be ?
Old Aug 4, 2019 | 02:57 PM
bealljk's Avatar
bealljk
Do you have a electronic copy of the factory service manual?
I would look up what causes P0345 to trigger and trouble shoot from there. Furthermore, what error is triggered by both the crank shaft position sensor and cam shaft position sensor.
I'd continue to search the forum on this issue - surely youre not the first.
Old Oct 12, 2019 | 11:53 AM
Vert's Avatar
Vert
Check all your spark plugs and coils. If those are fine, try resetting your ecu by disconnecting your battery for an hour. Not sure if you've read this https://www.fixdapp.com/blog/p0345 but its a good place to start
Old Oct 12, 2019 | 12:46 PM
travlee's Avatar
travlee
Master
2 months late to the party and op hasn't logged in since 8/15
Enticed
Jul 24, 2019 08:40 AM
DewsZ12
Jun 24, 2018 05:37 AM
JoeZee
Nov 6, 2013 03:24 PM
91180sr
Jan 8, 2013 04:58 AM
Abdulrhman Khal
Jul 11, 2011 12:26 AM
