2009+ 370Z General discussion and news for the Z34 (2009+) Nissan 370z with the new 3.7-liter V6
Roadster wet seatbelt
Old Jan 13, 2020 | 06:27 PM
Hokie79's Avatar
Hokie79
Default Roadster wet seatbelt
The passenger seat belt on my 2014 convertible is wet as it comes out of the retractor. I know this problem has been mentioned by others in previous threads but they didn’t appear to define a solution or fix. Any help/advice would be appreciated.
Old Jan 14, 2020 | 06:26 AM
jhc's Avatar
jhc
General & Tech Moderator
Do you have a tear in the top or wind noise with glass up on that side? You may need a window relearn found on YT. In the meantime pull the belt out as far as possible and clip in place to dry.
Observe the pass glass and door card next time you're out in wet weather. Check your front and back carpet also as mold and rust aren't your friends. Gl!
Old Jan 14, 2020 | 12:57 PM
Hokie79's Avatar
Hokie79
thank you for response. Car only has 11k miles and is usually only driven with top down, It does however sit outside in warm weather months and is covered with nice car cover during colder months. No tears or wind noise based on initial inspection but I’ll investigate further as weather permits. I’ll definitely dry out seatbelt as you define. Seat, door panel and normal exposed portion of seatbelt are dry. Just what’s hidden by panels is wet when seat belt is pulled out. I know others have had similar issues with either or both sides and hoping there is a simple solution available.
Old Jan 14, 2020 | 04:26 PM
jhc's Avatar
jhc
Perhaps. I've been lucky, DIY top replacement and window motors too, no leaks. Is the top OEM?
When it happens again post up pics before you wipe it down, it should be watertight.
Meanwhile cut some copy paper into 1' strips, insert 1 in each front and back ( top of window) then 1 at the rear.
Pull strips from the outside, you should feel resistance. GL!
Old Jan 14, 2020 | 06:49 PM
Hokie79's Avatar
Hokie79
Jhc, thanks again for advice. Ill try it and let you know how it turns out. Top is OEM and has had the fifth row bungee replaced. Another common issue with Z tops
DanOnTheRoad
350Z Roadster
21
Nov 27, 2020 12:37 PM
davidgroh
350Z Roadster
Sep 15, 2020 03:31 PM
mark350
Jun 27, 2003 11:58 AM
