Forged Performance: Alpha 10 GT-R Pump Gas Record + 957whp
We've had the pleasure to work on many of Doug's fun project cars over the years, but this one is definitely the pinnacle of his collection. His car made it back down to us from his home in Illinois after only being back in his hands for a few months. His previous 630 whp setup just wasn't enough to satisfy his need for power. He wanted a true street monster that would wax just about anything in its path while still being a civilized daily driver. The heart of the build consisted of an AMS Alpha 10 setup paired with our FP1-R 3.8L in-house assembled power plant capped with a pair of our FP Spec big valve cylinder heads. With these power goals in mind, several areas need to be upgraded including the engine, transmission, brakes, suspension, wheels and tires...the works.
Many of you recognize our tradition of building balanced track worthy cars that can still be driven daily. When tasked with building a very fast street car, our balanced philosophy is no different. We added a properly sprung set of JRZ RS Pro Silent Edition Coilovers, our Forged Performance Extreme Performance Sway Bar Set with Racing End Links, Endless MX72 brake pads, and a custom spec'd set of 20X10 20X12 HRE wheels wrapped in a square set of Michelin Pilot Super Sport Tires 315/35/20. We even installed a discrete Passport 9500ci radar detector and laser jammer to offer some modicum of protection from the law.
The acceleration is neck snapping while the handling remains razor sharp. Our transmission shifts superbly on the upshift and downshift, responding instantaneously to the paddles. There is a lot to be said for a car that not only makes tremendous power, but can also effectively lay it down to the ground and that's what we've accomplished here.
While we were planning this project, we knew this car was going to be a beast, but we weren't quite prepared for the end result, especially since we consider this a fast spooling balanced daily driven setup. After Sharif worked his magic in front of his Thinkpad, we made an incredible 838 whp @ 24psi on 93 octane on our low reading Dyno Dynamics! Like most shops that use unlinked dyno rollers, we ran the car in 2wd mode in order to preseve the front drive clutches. We were not 100% sure, so we had to confirm with AMS that this was in fact the highest WHP Alpha 10 on 93 octane to date. This car also made 957 whp @ 30psi at 8000rpm on C16 before our dyno gave out. Until we update our dyno software and run larger gauge power cables to the dyno, It appears we are going to have to go to another local dyno to complete the race gas tune on this monster. Stay tuned for updated race gas numbers in the near future! With 5psi left to go, it's no doubt this beast has more room to run.
Performance Modifications:
Forged Performance FP1-R Shortblock
FP Spec ARIAS Extreme Duty Zero Silicon Pistons
Manley Turbo Tuff I-Beam Rods
Forged Performance Stage 5 Ported and Polished Heads and Bronze Valve Guides
Tomei 272/272 ProCams VR38 Camshafts
Ferrea VR38 Full Valvetrain Kit w/ 1mm Oversized Valves
ARP L19 Head and Main Studs
HKS Head Gasket
AMS Alpha 10 Turbo Kit
AMS GT-R FMIC Kit
AMS GT-R Alpha IC Piping kit
Injector Dynamic 2000cc injectors
T1 Race Development Fuel Rails
FP Spec Fuel System with -8 Line Upgrade
CBRD Radiator
GTC 102mm Titan Exhaust & Y Pipe
PPG 1st Gear
FP Spec Stage 4 Dodson GR6 Upgrade Package (Promax Clutch, PPG 1st gear)
Transmission Assembly and Overhaul Performed In House at Forged
Cobb AccessPort w/ TCM
Other Upgrades:
Password JDM 38mm Wide Front Fenders
HRE P40 20x10.5/20x12 Flat Black
Michelin Pilot Super Sport 315/35/20
Escort 9500CI Laser Shifter & Radar Detector Kit
Forged Performance Racing Stainless Steel Brake Line Kit
OS Giken Rear TCD Differential
Pictures of the work:
93 Octane:
C16 Racegas:
The acceleration is neck snapping while the handling remains razor sharp. Our transmission shifts superbly on the upshift and downshift, responding instantaneously to the paddles. There is a lot to be said for a car that not only makes tremendous power, but can also effectively lay it down to the ground and that's what we've accomplished here.While we were planning this project, we knew this car was going to be a beast, but we weren't quite prepared for the end result, especially since we consider this a fast spooling balanced daily driven setup. After Sharif worked his magic in front of his Thinkpad, we made an incredible 838 whp @ 24psi on 93 octane on our low reading Dyno Dynamics! Like most shops that use unlinked dyno rollers, we ran the car in 2wd mode in order to preseve the front drive clutches. We were not 100% sure, so we had to confirm with AMS that this was in fact the highest WHP Alpha 10 on 93 octane to date. This car also made 957 whp @ 30psi at 8000rpm on C16 before our dyno gave out. Until we update our dyno software and run larger gauge power cables to the dyno, It appears we are going to have to go to another local dyno to complete the race gas tune on this monster. Stay tuned for updated race gas numbers in the near future! With 5psi left to go, it's no doubt this beast has more room to run.
HKS Head Gasket
AMS GT-R FMIC Kit
CBRD Radiator
PPG 1st Gear
Other Upgrades:
93 Octane:
C16 Racegas:
liqalu04
Jan 2, 2022 12:58 PM
