Roadster Chassis Rigidity
Old Oct 25, 2005 | 02:56 PM
JETPILOT's Avatar
JETPILOT
Default Roadster Chassis Rigidity
Compard to the 350Z coupe does the roadster give up much in respect to rigidity? Is the chassis tight and responsive or is their a lot of flex and slop.
I'm thinking of making the switch to the roadster but don't want a sloppy chasis.
Respect
JET
Old Oct 25, 2005 | 03:46 PM
westover's Avatar
westover
Default Roadster is rigid
I believe you will find the roadster to be a well handling machine. Nissan has added significant stiffening to the chassis and body panels to compensate for not having a roof. Who misses it anyway? I was recently on the track with my 04 DB Roadster at a performance driving school. The instructor commented on how well the car was balanced and handled through the corners. I have swapped out the stock springs for Hotchkis Sport Springs and the stock sway bars for Hotchkis bars so that may have helped out a little. Good Luck and have fun.
Old Oct 25, 2005 | 03:53 PM
RedLeader's Avatar
RedLeader
JetPilot-
I've driven a lot of roadsters over the years, including a 2003 Corvette, and my ZR has less cowl-shake and body flex than any other convertible I've driven. I think you'll be pleased. I vote for the roadster!
Bruce
Old Oct 25, 2005 | 05:26 PM
350zroadster's Avatar
350zroadster
The chassis is the same between roadster and coupe, and it's also shared with suv. It's significantly stiffer than most platforms.
Old Oct 25, 2005 | 06:04 PM
Netko350Z's Avatar
Netko350Z
Roadster is like the coupe on Viagra.
Old Oct 25, 2005 | 10:02 PM
FairladyZX's Avatar
FairladyZX
+1 ^
Old Oct 26, 2005 | 05:22 AM
jamnew's Avatar
jamnew
Respect
JET
Absolutely the tightest chassis I have ever driven. The roadster is actually a few hundred pounds heavier then the coupe due to all the extra rigidty built in to it. Go for it! you won't be sorry.
Old Oct 29, 2005 | 08:30 AM
Blue Komodo's Avatar
Blue Komodo
The Roadster is OK. It's not re-enforced between the rear shock towers like the coupe is. Add the roof to that and the coupe is much more rigid. If you put in any serious amount of track time, the S2K would be a better convertible.
Old Oct 29, 2005 | 10:06 AM
Vamos_Rafael's Avatar
Vamos_Rafael
+1 on the s2000
Old May 4, 2023 | 03:07 PM
jcandas's Avatar
jcandas
Unless you have wide shoulders ...
Old May 5, 2023 | 04:02 AM
travlee's Avatar
travlee
Master
you responded to a post from 18 years ago, and he hasnt logged in for 14 years
Old May 5, 2023 | 12:43 PM
jcandas's Avatar
jcandas
But you did
I just came back to the forum after a long layoff, someone might be watching LOL.
jlb
Oct 15, 2017 05:10 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
cashmoney03
Sep 27, 2015 05:24 PM
hardkicks
Sep 20, 2015 12:28 PM
