Fatty RDS
Old Jan 28, 2006 | 05:16 PM
jenna350z's Avatar
jenna350z
Default Fatty RDS
The roadsters weigh 257 pounds more than the coupe. Does ne 1 kno where the extra weight is? Or have any good diet plans?
Old Jan 28, 2006 | 05:19 PM
Built2shredZ's Avatar
Built2shredZ
Weight is in the extra reinforcment needed because of the removal of the roof.
Old Jan 28, 2006 | 05:23 PM
jenna350z's Avatar
jenna350z
Yea but what part of the car is reinforced?
Old Jan 28, 2006 | 05:54 PM
Built2shredZ
Would imagine the extra bracing is underneath the car and the sides (The frame of the car), also you get additional weight from the roof mechanism..
Could save a few extra lbs by ditching the spare tire (shrug)
Old Jan 29, 2006 | 05:35 AM
Netko350Z's Avatar
Netko350Z
There are 2 sets of weights...one in front and one in back... for counter balance.
Not sure how much total weight they are...
Old Jan 29, 2006 | 07:09 PM
ohw's Avatar
ohw
This part for sure - the roll bar.
Old Jan 30, 2006 | 04:55 AM
jenna350z's Avatar
jenna350z
Damn nothing dat i can really get rid of besides the spare tire. Just tryin to get my car light as a stock coupe.
Old Jan 30, 2006 | 01:55 PM
Built2shredZ
You can take off the two weights netko mentioned if you want, that should shave 30lbs off, but not sure what that will do for you handling as Im sure thats why the weights were put there.
Old Feb 10, 2006 | 07:36 AM
BamBam's Avatar
BamBam
There is also reinforcement in the front by the door hinge, that is one solid piece of framing to support the A-pillar in the event of a rollover.
Shave weight by replacing OEM parts with aftermarket parts. (Lightweight racing Wheels can save you 50+ lbs easily, replacing clutch/flywheel/exhaust etc are other options but much time consuming. Or put in racing seats, that could save you 30+ lbs per seat)
You could also look into replacing the sway bars with something made of a lighter but stronger material. And a good set of performance coilovers are usually lighter and smaller then stock.
--B
JCZ33
Oct 16, 2006 07:26 AM
marco_mendoza
Dec 23, 2004 11:26 PM
rbaggett1
Feb 21, 2004 05:20 PM
