To Bose or not To Bose
Old Apr 24, 2006 | 12:22 PM
turbogsr10's Avatar
turbogsr10
The Bose in the Z sucks. Sound quality is ok, but far from good. And mine broke. I had about 14000 miles on the car, and the damn thing is jammed. It won't eject my cd's, it won't play them. I have a Bose system with a FM/AM and a tape player. And it has 4 of my cd's stuck in it as well. But I do like my heated leather seats. So I'm getting an aftermarket head unit.
On the other hand, I had a 2002 TL type S with a Bose system and it sounded great. So maybe it's just Nissan + Bose = SUCK.
Old Apr 27, 2006 | 04:51 AM
SeanG's Avatar
SeanG
I too agree that the stock Bose system in the Z needs some help. The headunit is great. The rest of the system I replaced. I think it is a little unfair to Bose, they made a system probably to Nissans specs and price. Now if Nissan wanted to pay $4,000.00 per unit for their cars, I'm sure Bose would have produced a stellar system. So lets blame Nissan for the type of system that is in the Z, not Bose.
Complaining on a car forum that you are having issues with your piece of crap Bose as if no other Audio Manufacturer in the world makes systems that develope issues, is not very fair either. I have had numerous brands that have given me quite abit more issues than this Bose system.
I don't want to sound like I work for Bose or something, it just seems like the mobs gang up tactics are just a little tainted.
Old May 20, 2006 | 03:06 PM
TeesZ's Avatar
TeesZ
Originally Posted by rroppmd
I would suggest that you invest $360 in the JL Audio cleansweep 441-dsp interface for your OEM upgraded bose system with the subwoofer. You will get a dsp analyzed equalization over 30 channels. This will be a vast improvement over the stock Bose and leave you with another channel for ipod,dvd,or satellite radio. With this system there is no pull out, rewire, troubleshooting. Just hook the cable feeds as instructed and the factory harness, plug in a cd for analysis and you are set. Professional installation $300
I'd recommend the Rockford 3Sixty, it does way more than the Cleansweep, and its smaller and cheaper!!
Check out this thread...
http://www.carsound.com/forum/showth...ghlight=3sixty
Old May 20, 2006 | 07:02 PM
Z-CRA-Z's Avatar
Z-CRA-Z
Default Aftermarket
My salutation (footer) says it all.
Old May 20, 2006 | 08:28 PM
zYouLater's Avatar
zYouLater
I went thru 3 cd players and finaly dumped the bose. Go after market.
Old May 20, 2006 | 09:28 PM
zpeedDemon's Avatar
zpeedDemon
Bose=BLOSE
Old May 28, 2006 | 06:34 AM
rroppmd's Avatar
rroppmd
I decided not to change head unit or speakers and add a digital sound rocessing 30 channel equalizer. JL Audio makes such an add on called "Cleansweep". It is relatively inexpensive and will wake up the Bose system. You cant go wrong with JL Audio
Old May 28, 2006 | 09:10 AM
TeesZ's Avatar
TeesZ
Are you going to install the device yourself or have it done professionally?
Rockford makes a more powerful device thats smaller and cheaper than the CS, called 3Sixty.
3Sixty has 6 inputs, JL has 4
3Sixty internally sums if you need it, JL will sell you another device thats $150
3Sixty has 153 bands of EQ to correct, JL has 120
3Sixty has a programmable controller to function as a master volume or subwoofer level, JL has only master volume
3Sixty.1 gives you access to 15-wide Q filters post OEM correction to make a flat response sound good, JL gives you no access
(3Sixty.2 gives you access to all 153 bands, plus Xover, Delay, subsonic)
3Sixty has independant output level control, JL does not
3Sixty shows a before and after response to prove it works everytime, JL does not
The 3Sixty.2 has many more features but I'm trying to compare apples to apples and the 3Sixty.1 stomps all of the CS. The 3Sixty.2 is in a different catragory, all depends on what you're looking for.
Old Jun 1, 2006 | 08:53 AM
YBLegal's Avatar
YBLegal
no bose!
m_0g
Jun 3, 2021 10:05 AM
issyz
Sep 10, 2015 02:00 PM
droideka
Sep 1, 2002 04:00 PM
